Shadows render pass
v-cube
Thank you Paul !
as always I am anxiously looking forward to the next release - meanwhile I will try as you suggested...
best
Andreas
1 x 4090 GTX, 1 x 3090 GTX
http://www.v-cube.de
Attached is an experimental build with the Render Layers functionality.
2.23.2.39
- Added Render Layer field for Geometry items with Live Update enabled. This will allow Shadow Passes to be used (remember to enable Kerel->Alpha Channel when doing this)
http://render.otoy.com/customerdownload ... _64bit.exe
Set you geometry to Live Update, then assign the Render Layer. Then enable the Render Layers in the Rendertarget tree, and enable the 3 Shadow passes, and enable Kernel->Alpha Channel. Works really nicely.
v-cube
Hey Paul, thanks!!!
can I buy you a Beer ?
best
Andreas
Bendbox
You rock Paul !!!!!!!!!!!!
Win10x64 / AMD Ryzen 9 5900X / 64g RAM / 2 x RTX 3090
I take it that this works :-) Thanks
Return to “Rhinoceros 3D”
