Crashing Non-Octane scenes
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
shawnfrueh
The Problem/Crash happens when you select 'no' when the popup shows then go to a new/other scene and from there go back to the original scene and the popup happens again. Selecting no causes a crash.
If you cant recreate this problem I will try to get a video this weekend.
Edit: The null you put in the scene keeps getting put in the scene. If I delete it, save it and then reopen, that null is back. Even though I have no octane materials in my scene no tags and the live viewer has never been opened and not even any render settings (manually deleted the left behind data) This null and the vp are whats causing all these problems.
I did some changes today. Null will not be used anymore, also it will make the version convertion without any displayed window. I hope that can helps.
shawnfrueh
aoktar wrote:I did some changes today. Null will not be used anymore, also it will make the version conversion without any displayed window. I hope that can helps.
That should help a lot. I really appreciate the amount of work you put into this plugin.
Return to “Bug Reports”
