Maybe a solution, model your scene and parent it all to a model/null.
Scale the model/null down change your camera to the view you want and export.
face
Scaling issues in maya
http://vimeo.com/user2509578
- tehfailsafe
Ah! Gotcha.
So then the units from Maya DO need to be set in the script in order to make the command line execution work proper. Here's what is in the script history in maya after exporting:
Maya units: Centimeters
--cam-focaldepth 5 --cam-pos-x -207.1581278 --cam-pos-y 64.35848872 --cam-pos-z 95.01916412 --cam-up-x 0.116004769 --cam-up-y 0.9926767022 --cam-up-z -0.0337025009 --cam-target-x 45.58214977 --cam-target-y 32.3301564 --cam-target-z 21.59132571 --film-width 1024 --film-height 512
Maya units: Meters
--cam-focaldepth 0.05 --cam-pos-x -2.071581278 --cam-pos-y 0.6435848872 --cam-pos-z 0.9501916412 --cam-up-x 0.00116004769 --cam-up-y 0.009926767022 --cam-up-z -0.000337025009 --cam-target-x 0.4558214977 --cam-target-y 0.323301564 --cam-target-z 0.2159132571 --film-width 1024 --film-height 512
Makes sense. Bazuka, you said you recently removed the scaling settings? Maybe they still need to be in there?
Maya units: Meters
windows 7 64 bit| GTX580 1.5Gb x2 | Intel 2600k @ 4.9 | 16gb ddr3 | 3ds max 2012
- tehfailsafe
Thanks for the help face!
I also figured out the problem with the blurring I was having. I guess when you create a new camera the focus distance defaults to 5 units. When I was switching around from cm to meters maya updates the focus distance as well...
So I created camera while maya units = cm so the focus was set to 5 cm. Changing units to meters to get the camera to export correctly changed the focus distance to 0.05, thus making everything out of focus.
Phew, now I can get back to learning to use maya itself!
yes i had to remove coz of animated obj, groups and visibility obj inside the groups
obj will export all object in the scene no matter if the r visible or now (if u choose export all)
if u choose export selected then i have to select only object inside the group that they r visible and export them separately
its complicated with animated/rigged object in maya coz everything is in the group
im still brain storming scale thing, i have some solutions but need to be tested...
cheers
cheers
Maya 2009 x64 & Maya 2011 x64
Windows 7 x64 & Windows XP x64
2x Quad Core Q6600, 8gb, Nvidia Gtx 260 & Gtx 460
Any luck finding a better solution for the Maya exporter? I'm having similar issues with scale atm. Right now my workflow is to switch Maya to meters, scale the object correctly (it's roughly 40x40mm in reality) create my camera, and export to Octane using Maya2Octane v2.4. The camera is ALWAYS completely off regardless of whether I set Octane to Meters to Meters, Centimeters to Meters, etc... I've tried keeping Maya in meters, scaling up the entire image to 100x via a group and repositioning the camera - same results, the camera is positioned as if it's still scaled 100x off... I'm so confused as to what the proper workflow is for Maya in order to keep everything properly scaled in both applications. Could someone clarify from step 1 how they're managing?
Thanks a ton!
Thanks a ton!
Core i7 920 | 12 GB RAM | Nvidia GTX 470 & 260 | Win Vista x64 | Maya 2012.5 x64 | Octane beta2.57
well im not sure either, but here is how i do it
i do everything in maya in cm and thats it, didnt have any probl so far
could u send me scene (dont need eveything) just some basic stuff, cam and some ref obj (box, sphere) and ill see what i could do about it
You guys need to get your shit together.
It's pretty basic conversion. I can't believe a version 2.5 exporter doesn't work. Was it released 2.5 days? Hehehe I'm just joking.
Pulling out scale function in script because people have problems with animation is no solution. If anything, those people should do a maya geo cache first and try to export a rig-less file. Which is the Model an no rig with Maya Cache attached. You can scale that on export all over the place without any issues.
If anyone is coming from Maya they treat 1 Maya Unit as 1 CM. I use V-Ray everyday and the Math is in CM. I understand Octane is Meters, but that doesn't help us Maya users.
Can't you just put all geometry and cameras in a group and scale it by 0.01 ? I think this is what face suggested.
