C4D Demo - A Few Problems
Zee
Live viewer demo 2.16.2
C4D R16.038
Without any tags or anything additional, when I move already existing objects around in the scene it used to update them in the live viewer without any additional tags. I can see the exact behavior happening in almost all of the octane tutorials also. That's why I thought maybe something is not quite right on my end.
I've attached a remake of my initial test file where I could simple move the cubes around and see it updating when I was testing the earlier versions of Octane. I'm not sure if it was working before with this current version because 2 minutes after installing it I messed up the settings but; right now I can tell you that it's not behaving that way.
The last time I've tried octane before this (where I'm SURE this was working) was at least 1 year ago though.
octane_test_02.rar
Initial Test File
(93.23 KiB) Downloaded 175 times
don't know what you see but i have tryed to show that expected behaviour even with some settings. Please give to me more info
See video here:
http://www.aoktar.com/aoktar_test.mp4
Zee
I've attached a test screen recording to show what it does not do. I know it does not have an octane object tag, but it used to work like that as far as I remember so I'm wondering :)
Cheers
test recording.rar
Test Screen Recording
(9.1 MiB) Downloaded 250 times
ok see. That's expected behaviour. It updates materials, camera, lights, environment by default. Not objects. You should set on "Check geometry" for this as i said.
Zee
With or without the tags? Check geometries is already enabled (no tags as you can see)
Thank you
with object tag
