Crystal Glasses
sean60274
cool stuffs.
displacement and bump can applied at same time on the same mat, it might easier to control how smooth the glass surface is.
Intel Xeon E5-2689 2.6 GHz x 2
DDR-3 40 GB
GeForce GTX 680 + GeForce GTX 770
polytek
simply beautifull, do you mind showing me the way you unwrapped the glasses, been strugling myself with desent unwrapping and then applying displacment maps, it usely shows up being crap...
High regards,
Poly
win 8.2 / 64 / systemmem 27Gb / gtx 750Ti & asus stricks Gtx 780 6Gb
HHbomb
Nice renders !
Can you please tell us how you model the glass and liquid ? It is a question that had be asked a lot on octane render forum.
(Is there a space between glass and liquid, do they share same faces or are they overlaping ?)
Thanks.
Sportler
polytek wrote:simply beautifull, do you mind showing me the way you unwrapped the glasses, been strugling myself with desent unwrapping and then applying displacment maps, it usely shows up being crap...
High regards,
Poly
Here is a quick display of UV's and the displacement texture :)
UV's of Wine Glass is basically rectanglifying the are around it as good as humanly possible, same for the inside. Top and bottom is essentially just a planar projection.
Texture only needed for part of it, so if you are lazy you can only unwrap that part, although bump maps will look better if you do the eniter thing:
HHbomb wrote:Nice renders !
Thanks.
As for this, absolutely. I use the Maxwell way, as described on their forums. I figured since both render engines are unbiased, it should work perfectly. It does :D
Here is a quick sketch of the geometry and the normals:
And a semi close up of the wireframe:
And a super close up of the unsmoothed geometry:
Hope it helps, and glad you liked the renders! :D
GPU: 1x Nvidia RTX 3080 Ti
RAM: 64GB DDR4 3200MHz
CPU: 5950x
HHbomb
Thanks for sharing Sportler !!
here is the link I found for maxwell trick : http://support.nextlimit.com/display/tu ... in+a+glass
cheers
polytek
thanks for sharing, intresting stuff indeed,
High regards,
Poly
Lesiu
There's something strange about wood, but the rest (glasses) is totally fine. Good job.
wastzzz
Impressive, yeah.
M.
