texture viewport cinema4d
sciontidesign
Hello aoktar
ok i did it saved my scene restarted Cinema4d and now i could see textures in cinema4d :)
Thank you hope will work fine
garytyler wrote:I am glad I found this thread because I'm experiencing the same issue with some of LiveDB materials. In general, I'm finding the LiveDB materials to be great when they load properly but they seem to load buggy and sometimes not work very well. Also, I do have the latest update.
These are user made materials. Do you mean opengl previews?
sciontidesign wrote:Hello aoktar
restart or reload or some click can trigger refresh of opengl textures. Nice to hear you solved the issue
sciontidesign
Hello this is screenshot now bench are no more black
lextrickett
Hi Aoktar,
I checked that setting now and there is still no change.
Lex
lextrickett
I have restarted and no change. Other textures are working fine but my mix texture is still not previewing correctly
Lex
Gumz
I have the same problem. It seem to be random which textures are shown in the viewport.
I'm using r16 and v2.12.1 of Octane.
this is also my capture for mix material. It's working as you see. Can you post a sample scene for me? Let's check what's the problem.
lextrickett
Hi, here is my scene file.
thanks so much!
Lex
MRPGL_NEW.zip
(16.92 MiB) Downloaded 247 times
lextrickett wrote:Hi, here is my scene file.
thanks so much!
Lex
Hmm, it's working here. Settings window can be seen also. But i have notified it happens on Macos. That's why we want that you should write system and version specs. I'm checking what's wrong on macos.
