OctaneRender® for 3ds max® v2.11.1a
User avatar (Default)
merid888
thank you karba, i'll test later
mykola1985
no bugs so far.. ;) will continue testing!!! :)
i7 3770K, 12GB RAM, ASUS STRIX GTX 780 - 6GB OC Edition + ASUS GTX 780 Ti - 3GB, win 7 ultimate 64bit
darkline
Has the triangle limit been fixed in the last few updates?
Windows 7 64bit/ Intel 3930K/ ASUS Rampage IV/ GTX980ti x 2/ 64GB system RAM
vyle-art
Hi, I am testing network rendering using 2.11.1a plug in with the 2.11.1 standalone. Is there a switch that needs to be activated for viewport rendering? I turned on the slave in the network configuration tab and it states that the slave is running and enabled. Yet I am unable to see any difference in the viewport render times at all. Am I missing something? Really wish there was documentation about network rendering with 3ds max.
Any help is much appreciated
-David
coilbook
vyle-art wrote:Hi, I am testing network rendering using 2.11.1a plug in with the 2.11.1 standalone. Is there a switch that needs to be activated for viewport rendering? I turned on the slave in the network configuration tab and it states that the slave is running and enabled. Yet I am unable to see any difference in the viewport render times at all. Am I missing something? Really wish there was documentation about network rendering with 3ds max.
-David
I had once where my main pc would detect slave but slave wont render turned out that on slave i accidentally installed 32 bit stand alone instead of 64 bit Hope it helps
vyle-art
Thanks for the quick reply. I checked and I installed the proper version, 64, so it probably is something else. Checking all my versions:
Octane render is 2.11.1a plugin.
Standalone is 2.11.1 win64
We also tested on cinema 4D plugin and have had no problems.
Any help is appreciated,
- David
vfxman83
Hi there;
The octane light visible option like an vray invisible option but if you uncheck the visible option the light doesn't effect any surface mesh such as but vray effects light color Can you fix this on the next realese ?
Thank you.
mark0spasic
Thank you for new release.
I found bug, noise is only static in upper left corner of image the rest of image has dynamic noise.
AMD FX 6300, 24 GB RAM, Gigabyte ga-990fxa-ud5, 2x MSI GTX 780 3GB
coilbook
mark0spasic wrote:Thank you for new release.
I agree
Sometimes it seems to me that static noise does nothing everything still moves like crazy
gabrielefx
issue:
merging Octane proxies (from two scenes with different units) the scale is not respected.
Hi Karba,
could you add zipped proxy feature?
