OctaneRender for Modo 3.03.3 [STABLE]
funk
Thanks Paul. It seems there is a bug with saving tonemapped EXRs. They are saving with the wrong gamma (washed out). I reported it to the standalone thread.
I just checked this, and can reproduce the issue.
I have refreshed the installer at the top of this thread with:
2.11.1.32
- Added ability to save Multi-layer (untonemapped) EXR from the Save button
- Added ability to save specify Multi-layer (untonemapped) EXR when rendering an animation. IMPORTANT: You must set Start Samples (in the Render Passes panel) to 1 in order for rendering animation passes to work correctly
Dmi3ryd
Hello Paul. Thanks for update.
I've trying to save multilayer EXR with AO pass. The only black in screen, no information.
Win 8.1/64 | Geforce GTX780TI | Core I7 970 | 24GB
LFedit
I have been looking for the release notes and I can't find them anywhere. Could you post a link to them?
Which release notes are you after pls? The Modo plugin (which are a few msg up from here), or Standalone (which are at http://render.otoy.com/forum/viewtopic.php?f=33&t=42854).
LFedit
Was the standalone, looking for the static noise kernel you were talking about. Thanks.
Hi Dmitry - you are right. It is because the plugin thinks rendering all passes has finished when some of the later passes haven't started yet. I will fix this.
If using the standard Save button to save a single frame, you need to wait for all render passes to finish rendering.
LFedit
Can the manual be updated for the render passes? In the manual, the selections are different... I don't have the specular or a few other options listed...
http://render.otoy.com/manuals/Modo/?page_id=1058
Render passes are "beta" at the moment, so we can expect a few changes over the coming releases. Once the functionality has settled, I will re-do the manual page to better reflect the final functionality.
Return to “Foundry Modo”
