Calibrated camera/ Background plates / projection man ??
renric
Thanks man just got it working right now as i wright this, love this render and the work you are putting into it
What's your workflow?
I am currently working on a project and using projection man.I have all the geometry setup using advanced render.
When using octane perspective projection or the camera mapping on the tag I get a different aspect ratio from AR. After fiddling a lot with the scale values on the Projection from the imageTexture node I get something close to the original, but I get 1-3px difference, not ideal.
I would appreciate if someone knows what I am doing wrong or there is any specific workflow.
Many Thanks
Many Thanks
is it possible to send me test scene?
renric
Hi Aoktar,
Many thanks for looking into the scene.
I stripped down the geo and textures and there is only the original plate.
I would appreciate to know what I am doing wrong.
Thanks again.
PRM_2OC.rar
(30.49 MiB) Downloaded 190 times
Spent some time to fix. I hope this is better, teorically this is correct way. Also you can check "Cameramapping2.c4d" scene. I hope this would help to you
PRM_2OC-1.ZIP
(155.98 KiB) Downloaded 203 times
