Octane for Softimage 1.02 RC10 [Obsolete]
Autodesk Softimage XSI (Developed by Face)
abeoctane
Hi face, I think a found a bug, I been trying to render the frame 144 of my animation as png, but octane save it as frame 180, I checked it and yes it is the frame 144 but with a wrong name, what could it be?, thanks.
face
abeoctane wrote:Hi face, I think a found a bug, I been trying to render the frame 144 of my animation as png, but octane save it as frame 180, I checked it and yes it is the frame 144 but with a wrong name, what could it be?, thanks.
Hm, with motion blur enabled?
Or happens it only with frame 144 and frame 145 is ok?
face
http://vimeo.com/user2509578
abeoctane
This happens too in other frames, this is the scene, thank you.
test_frames.zip
(178.37 KiB) Downloaded 578 times
abeoctane
Also, skip rendered is not working, this is very important for me because I can´t render with two or more machines, :(, hope if you have time could relase a RC11 soon, thank you.
abeoctane
Annnnd It is skipping frames, for example it renders frame 001, 003, 004 ,005, 006, 008, 009, 010, 011, 012, 014... and so on, even when the forlder is empty.
abeoctane
I looks that octane is not skipping frames, it gives them another number, I don´t know for sure, and this is worse than not having them, because after effects will ask for frames that it do not detect but, in fact are there with another number. :cry:
face
Have also found an other issue with your testscene.
When the image folder isn´t existent, the plugin will also crash.
Will fix this first and then i will show what happens with the other issues...
face
abeoctane
I have found another one, the frame range in the pass options is not working, I have my pass to render from 30 to 60, when the render finished in the render folder are frames named from 30 to 60, but they are the frames from 1 to 31 in my animation, just with different numbers.
face
abeoctane wrote:I have found another one, the frame range in the pass options is not working, I have my pass to render from 30 to 60, when the render finished in the render folder are frames named from 30 to 60, but they are the frames from 1 to 31 in my animation, just with different numbers.
I don´t know, after i have made changes, i can´t see the issue.
Maybe it is solved with the changes i made.
I can make a quick build of a dll which you can test, if you want.
face
abeoctane
That would be awesome, I have to send another render tonight, thank you very much. :D
Return to “Autodesk Softimage XSI”
