OctaneRender® for 3ds max® v2.02
suvakas
Karba wrote:3dsmax doesn't allow me to access hair&fur geometry by regular way, I am very limited here.
What about material support? Can't you write your own implementation on top of standard hair?
You should be able to define material for Octane hair primitives using Octane sdk? Can you change root and tip colors of Octane hair primitives?
Also can't you access Mental ray material slot under Hair&Fur ? This is where the material is assigned when using Mental ray. Would be nice if it would work with Octane materials too.
[edit]
If you use "geometry" under Hair rendering options, then maybe this will make the hair geometry accessible in more standard way? No ?
Suv
gabrielefx
Karba wrote:
gabrielefx wrote:Thank you.
do you fixed the opacity map issue?
opacity map issue? have I missed something?
yes if the texture is a grey scale large 1024 pixels is ok
when is 1025 or more pixels it doesn't work.
Karba
twinsk8 wrote:Hi Karba , when i opened octane render viewport, it crashed like that picture:( i will returned 2,01...
May I have your scene?
[email protected]
Karba
Both images work in this version.
coilbook
were you able to fix random color not working ?
Karba
coilbook wrote:were you able to fix random color not working ?
It should work
acc24ex
let me play this game of "did you"
umm, did you fix the pathname with spaces issue on LiveDB
.. did you.. fix the resolution lock / region render not working thingy .. ?
Karba
acc24ex wrote: umm, did you fix the pathname with spaces issue on LiveDB
Not yet
acc24ex wrote: .. did you.. fix the resolution lock / region render not working thingy .. ?
lock resolution works differently. in this mode you can't zoom, scroll, and do region render. I have to disable region render button in this mode.
acc24ex
- OK thanks for the reply anyway - I see that nobody else cares about those, remember that saying, it's not a bug it's a feature - as long as you report it beforehand
emihich
Missed any button ?
Image :?
Return to “Autodesk 3Ds Max”
