OctaneRender™ Standalone 2.00
glimpse
smicha wrote:Just bought the update - huge thank you guys for your hard work.
Region render - is it natural that when I select a tiny region, speed of rendering drops dramatically - even 10 times?
maybe they cheeted here: You know all they make is just mask for us to think that it's region render =) when all it's is not showing periferal (unselected) piece in action =DDD
Cruel Joke, sorry, let's check =)
smicha
2. Subdivision level - I can set it globally via preferences. Is there a way to set it for an individual obj only?
vimaxus
Can someone please post a link where we could buy the update? not the standalone at 300.
I've spent the last 10 minutes searching for it at I can't see how it wasn't mentioned in the first post nor the email announcing it as I suppose the aim it to make the current user pool upgrade their licences not buy new ones.
smicha
vimaxus wrote:Can someone please post a link where we could buy the update? not the standalone at 300.
Go to "BUY NOW" and hit the top right button "UPGRADE FROM 1.0"
glimpse
go to main site: http://render.otoy.com/
and press UPGRADE button on a pop up window =)
vimaxus
Ok thanks guys! Now anyone knows about the plugin upgrade? Like how long is the period mentioned here:
For a limited time, users who upgrade to OctaneRender™ 2 can also upgrade an existing plugin license at no additional cost to make use of an available OctaneRender™ 2 plugin or receive a voucher towards the 2.0 plugin when it’s available.
or maybe where are we to find such voucher?
smicha
3. I am trying to use the "random color texture" node to pin to the "3D transform" node to translate a texture over instances in e.g. X direction randomly. There is no way to do it. I asked for this feature here
http://render.otoy.com/forum/viewtopic.php?f=9&t=39912
and face_off said:
"You can feed the new Random Color Texture (which is a random color between 0 and 1 for each instance) into any compatible pin, including rotations and scales in projection nodes. So I may provide a lot of what you need."
So guys please let me know if this is possible, or if not yet - when?
Here is a simple example in .orbx format of rendom color node assigned to some cloned cubes:
rendom-color-or2b.rar
emendix
Just gave it a try (just some features, not all of them) and im very impressed! You guys did a great job!
smicha
bepeg4d wrote:Here is a simple example in .orbx format of rendom color node assigned to some cloned cubes:
beppe,
I am not talking about random colors - it is obvious. I am talking about random transform values, i.e., I want to move,rotate or scale texture over instances randomly in certain direction. So I would expect a node that allows me to set: min, max, step (optional), seed.
Let me give a short example: I have a 1x1x1 meter cube and I want to move an image texture over it in X direction randomly, but no more than 30cm to the left, 50 cm to the right, by +-5cm step randomly (using uniform distribution). So I would enter into the random value node: -0.3 (min), +0.5 (max), 0.05 (step), 0 (seed).
This is what I mean by random values.
