hello and thank you.
I should add just a little dirt on the main texture .... I'll try just a bit of time.
							Little Devil Statue
- jmlepretre
Hi ironelix,
By the way, could you tell me how you opened your 'little_devil2.obj' in order to see all the connections in the graph ...
for me it doesn't open.
Jean-marc
Jean-marc
XP32sp2 - 4Gb(3.12)- Core2Quad @2.40Ghz  - MSI 260GTX 896Mb
						that's cool, the material helps it's realism.
						I did see that, but it looks like it's only touching the base by the toes. Even if the material was strong enough not to break on that small section of contact, judging by the size of the base and the statue, the whole thing would probably topple over.ironelix wrote:..Daniel it is mounted on support base..
Core i7 950 @3.07GHz | GTX 460 2GB | 12GB RAM | Window 7 x64
						- jmlepretre
no thanks, it's ok nowironelix wrote:
@ jmlepretre:
Hello what do you want to know specifically?
i see that you can open in graph only things made from scratch in Octane (this is strange and time consumming but there shuld be a good reason)
