Let´s speak over the "Fractal" shader as example.
Each renderer will have a version with which he can work. Also one version for the Maya renderer, one for MentalRay.
To use this shader in Octane, we need also a new version which runs with Octane.
To explain it a little bit better.
Each shader is a little program which has some input ports, some outputs ports which are filled with color information.
This information is calculated from the renderer.
As example without to be correct, the Maya renderer reads in the color information from an image with position x and y.
MentalRay will also read the color information, but with y, x. You see, this doesn´t match.
As a sidenote, it isn´t possible to share data between different render engines. You can use either this renderer or that, but not this and that.
Ok, back how to create the "Fractal" shader in Octane.
The big problem is to know, how the shader calculate the fractal.
We can go different ways of calculation, but the result wouldn´t match the result from Maya or MentalRay.
And remember, the result we get is only an image with an x/y resolution which must be mapped to the surface.
It´s the same when you create a fractal in Photoshop and use it as texture in Octane.
Over the API we have only the possibility to fill in a texture with some colors.
face
Maya texture.outColor for Octane Materials
http://vimeo.com/user2509578
- dionysiusmarquis
Yay I really appreciate your explanations. Thank you for that. I thought that it's always possible to get the color Informations using the software Renderer as it's always possible to use it via the Hypershade to convert textures to files completely independent from the selected render engine and even while you'r rendering.
I think I will write a script which uses convertSolidTx to write switching temp files for the Octane file texture Node as a workaround.
I'll ask at Autodesks Maya Forums if its somehow possible to use the software render to get the Pixeldata renderer independent. Would this help?
Last edited by dionysiusmarquis on Fri Mar 21, 2014 11:28 pm, edited 1 time in total.
I don´t know that, im not a Maya boy
But it can´t ever be wrong to ask.
face
face
- dionysiusmarquis
Double Kudos for your efforts!face wrote:I don´t know that, im not a Maya boy
MentalRay is MentalRay if in Maya or in Softimage. The same is with Arnold or 3Delight.
They all use her own shaders and use/convert the standard ones more or less...
And if a question is interesting, then i can also answer
face
face
- dionysiusmarquis
Yay I found something:
http://download.autodesk.com/us/maya/20 ... 0c015ddf20
As far as I understand its possible to sample any Texture color (2D/3D) with any Renderer.
http://mayastation.typepad.com/maya-sta ... xture.html
I'll start testing how fast it is. It would be really nice to be able to set the buffer of a rgb or float node just like in lua.
texturenode:setAttribute(octane.A_BUFFER, buffer)Looks like a baking feauture.
But i don´t know how you will transfer the storage of the resulting colors to Octane.
face
face
- dionysiusmarquis
for i in range(resultColors.length()):
resultVector = om.MFloatVector(resultColors[i])
rgb = [resultVector.x, resultVector.y, resultVector.z]
sampledColorsArray.append(rgb)Code: Select all
sampledColorsArray = [r, g, b, r, g, b ...] = [125, 125, 125, 255, 255, 255 ...]That should match but how you got the array to Octane?
I think you will get the data from the renderer which is current selected.
To work with Octane, you have to switch the renderer to Octane, how should this work?
face
face
- dionysiusmarquis
No i think you can get the Pixel data at any time. The MRenderUtil commands aren't related to the selected render engine i think.
Edit: I'll test it. And report back
