"failed" error on 780ti
aw1
shader ball is working.. trying with materials and it seems to work fine..
Windows 7 Pro, i7 4770, 16 GB Ram, 1TB SSD, Asus GTX780Ti 3GB
aw1
i just made a new PC with this 780ti.. installed all latest driver from nvidia..
aw1
ok the Shaderball failed too !!! yes i restarted the computer too!
here is the log:
Started logging on 26.02.14 19:56:28
CUDA error 715 on device 0: Error code unknown.
-> Kernel execution failed (pmc)
CUDA device 0: PMC failed
GPU overheat?..:?
aw1
how do i find out that gpu is is heating? is there anyway?
abstrax
aw1 wrote:ok the Shaderball failed too !!! yes i restarted the computer too!
here is the log:
It looks like a hardware issue to me. If this is a new 780Ti, then I think the card is broken and you should ask for a replacement. If not, it could be anything, like the motherboard or memory or the power supply. To be sure that it's not a driver issue, you could install an older graphics driver, but my bet is currently on a hardware problem.
abstrax
aw1 wrote:how do i find out that gpu is is heating? is there anyway?
There are several tools out there. Just search the Internet for "gpu monitor".
aw1
+1 for hardware.
New computer, new GPU, and error looks like hardware problem...
But you may not notice the overheat if e.g. there is a bad connection between GPU processor and cooler (e.g. no termal paste, or something between them...). In this case the overheat may be reached so quickly, that you will not notice it in the tools before GPU stops...
Just IMHO...
Zay
You can use GPU-Z to monitor your graphic card:
http://www.techpowerup.com/downloads/23 ... -z-v0-7-7/
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 581.57| Modo/Blender/ZBrush/Daz/Poser
gabrielefx
check your gpu with another gpu based renderer.
