Thin Lens Camera has these 'lensShift' parameters that let You offset picture plane without moving camera (and changing perspective). tip1: leave a bit for overlapping, this way You can use mask subtly connect those images, otherwise there might be visible seems. tip2 don't use vignetting =DDDElBloko wrote:I intend to make a large print of this but found out that the maximum render size in Octane is limited 8k*8k. Does anybody know a workaround to this?
Origins - Personal Project (NSFW?)
Beautiful work! Nice execution.
Thanks! I figured out the lens shift trick. It works perfectly and I managed to render something very clean at three time the 8k buffer size.Thin Lens Camera has these 'lensShift' parameters that let You offset picture plane without moving camera (and changing perspective). tip1: leave a bit for overlapping, this way You can use mask subtly connect those images, otherwise there might be visible seems. tip2 don't use vignetting =DDD
I haven't looked into it at all but I assume a simple LUA script could automate the process too. That probably is something I'll put together soon if anybody has any interest.
Thank you all for your help
- RealityFox
This is a fantastic renderer and the node web is really helpful! Would you be willing to make a little step by step on how it was accomplished? If you have the time and such (as well as willpower). It would just be a very helpful thing for beginners (such as I) to see.
Anyway, it's a great render! Thanks for sharing!
Regards
Samuel
Regards
Samuel
Great piece of art ! Congratulations !
- p3taoctane
quite stunning.
if you get that lens shift script done I'd love to try it. i have to do a wall size piece that needs to be sharp from a foot or two.
A script would make my stitching job a lot easier.
Nice work
Peter
Nice work
Peter
