OK... Just purchased a new Graphics card...
samhal
Feels good huh? Even tho I have a 'lesser' card, I have two of them, 4GB vram each with about 2400 cuda cores. Only one scene I've come across that I ran out of texture memory for...and that was an easy fix (Thanks Paul!)
Render on brother!
i7 6800K (6 core), 24 GB, GTX 1080 8gb, Titan X 12gb
gah5118
just got a 780ti also, and cut my times in half from my old 580 that was wearing out after 3 years. at work we are about to do either 1 machine with 4 titans or 2 machines with 2 or 3 (for redundancy if one fails aaannndd its looking like they may be introducing network rendering via that poll they had which would be AMAZING)
Windows 8.1 | i7 950 | GTX 780ti | 24gb ddr3
RGUS
Sent the GTX 780 Ti back... didn't like the limitation on scene size... swapped it for a GTX Titan SC (super clocked)... any scene is possible now... one I'm doing right now is 3952/6144MB... still got room to poke another V4 in there with textures and full armour.
WEB: http://rgus.deviantart.com/
GPU: NVIDIA GeForce RTX 3090 Ti
RAM: 64GB
CPU: 12th Gen Intel(R) Core(TM) i9-12900K 3.20 GHz
OPERATING SYSTEM: Windows 11 Pro
OCTANE PLUGIN VERSION: 2025.6.0.4.09 Prime BETA
DAZ STUDIO VERSION: 4.24 Pro Edition (64 bit)
gah5118
nice; i was real close to getting a titan at home, but i mainly do gaming at home; 780ti will fit the bill for both... at work though we are getting setup with 3 titans in each of 2 machines for rendering so that should run rather smooth.
the titan is diffidently the best option if your scenes are getting large though.... mine are usually around 1-2 gb
ArminBeier
I have 2x GTX780 GLH.
Is there a way I can use the RAM of both cards?
Right now it's limited to 3GB, which is just one card!
edit:
ok, found on other threads that this won't ever work....
so is my second graca completely useless for octane?
OS: Win7 x64
CPU: i7-4770 @3,40GHz
Mainboard: Z87-Deluxe
GPU: 2x GTX980 Ti Hybrid
RAM: 32GB
HD: 250GB SSD
RGUS
That's why the 780 went back, the Titan gives 6GB to fill a scene with.
RAM: 64GB
samhal
ArminBeier wrote:I have 2x GTX780 GLH.
edit:
No, not completely useless! Octane will use the CUDA cores from both cards which counts for ALOT! I'm in the same boat with 2x 670 cards, each with 4 gb VRAM...I only get 4 GB and not 8 out of this setup. But still, 4gb is not bad!
If 3GB is not big enough for a particular scene - use the Compress Texture Maps python script supplied with the plugin to reduce the size of the texturemaps.
Return to “Poser”
