Ambient Occlusion pass.
Rob49152
Builtdown wrote:Hi,
When you render your AO image, put a low emission node value for the areas you don´t want AO to show?
please forgive my stupidity (I have a lot of it) But what's a 'low emission node'? I have not heard of this in octane before.
CPU: Intel I9-14900KF | Mobo: Asrock Z790 Tachi | Ram: 128gb | Storage: 64tb | GPU: 2x Asus ROG Strix - RTX3090 24gb
Builtdown
Texture emission node with low power value.
So the polys are lit but won´t light the scene. And occlusion wouldn´t be shown on these lit polys.
Micha
Nice trick, thank you for sharing.
http://www.simulacrum.de - Visualization for Designer and Architects
Win7 64 | Dual Xeon E5-2687W | 32GB RAM | 2 GTX 780 6GB | Rhino3D
Rob49152
Builtdown wrote:Texture emission node with low power value.
The surfaces already have texture emission nodes attached to them. AO overrides everything and ignores any emitting surfaces in the scene.
The only thing you can have in an AO pass is the option to do 'Bump and Normal mapping' on surfaces.
Builtdown
Don´t use AO pass. Use Direct Lighting Kernel with AO Gi type.
Rob49152
Builtdown wrote:Don´t use AO pass. Use Direct Lighting Kernel with AO Gi type.
Ah Ok. Now I understand what you mean. But I don't want to use Direct Lighting kernel. I want to use PCM or Path Tracing with a separate AO Pass in a beauty pass for more control.
Builtdown
I always render a beauty pass with Path tracing and a separate image with Direct Lightning AO and compine them with Photoshop or if making an animation, then with After Effects.
Return to “Lightwave 3D”
