OctaneRender® for Poser beta WIN - build 1.17a [STABLE]
mlru
I like that new material picker. Much more convenient :)
Win11/64Bit | GTX 4090 24GB | NVidia Driver 546.29 | Octane 4.05 | DAZ Studio 4.21
ch0pper
got this error message
Traceback (most recent call last):
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\Node.py", line 887, in EventLooseFocus
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\Node.py", line 1938, in EventNodeChanged
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\Node.py", line 491, in SetOctaneApiNodeValue
WindowsError: exception: access violation reading 0xFFFFFFFFFFFFFFFF
W7 64 bit |I7-3970X | GTX 780 X2(6GB) GTX 780TI X2 | 64 GB DDR3 RAM
Real Skin & real hair for Poser / DAZ Studio OctaneRender/iray - coming soon
JeffGalloway
Possible minor bug in 1.17.
When selecting a number in the Render Options List or Materials List, the editable number is not selected. You must chose the number and again select the number below - at the bottom on the window.
Chopper, was that random, or reproduceable? What were you doing when you got it? Can you remember of the Viewport was open or not? Had it been open then closed? Was it on the Settings tab or Material tab? Can you remember if it occurred after you imported a material?
Fixed in the next release.
Zay
Was using Stonemason's Urbansprawl2. When I closed the scene (File/Close) I got this:
  File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\ViewportForm.py", line 703, in on_timer
AttributeError: 'NoneType' object has no attribute 'p3'
Exception in deleteObjects: Invalid Scene object
Last lines in the log:
DEBUG:root:init:sceneDeleted
DEBUG:root:Closing settings window - clearing callback
DEBUG:root:Closing settings window - saving window locations
DEBUG:root:Closing settings window - closing viewport
DEBUG:root:Closing settings window - reseting project
DEBUG:root:Closing settings window - destroying window
DEBUG:root:ignoring init:objectsDeleted
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 560.94| Modo/Blender/ZBrush/Daz/Poser
The Setup window closed as the Viewport was trying to refresh. Fixed in the next version.
bpzen
Hi Paul, do we need to install build 1.17a stand alone to use this plug in build? Also, were do we get the download for the build 1.17a stand alone version?
Win 7 64bit, Titan 6 Gig and GTX770 4Gig, Intel 3.75GHZ, 24Gig RAM, Poser 2014 patched
You don't need Standalone. Pls see http://render.otoy.com/manuals/Poser/?page_id=18.
I have refreshed the installer at the top of this thread. It contains an important bug fix (third point listed below), so pls download and install.
1.17a5
- Selecting a tree item now correctly selects float and int edit boxes in the node edit box
- Fixed issue where a python exception was raised if PoserPython closed the Setup window prior to the Viewport
- Fixed issue where clicking the new "absorption" node pin "priority" was raising a python exception. This pin is not used and can now not be connected
Return to “Poser”
