1.13c Proxy testing feedback
- Garquitectos
- Contact:
I has some crash when the plugin is "voxeling" and I try to move the octane palette at the same time.
Octane Render for Archicad, Archicad 16 Spanish, Bimx. - Win 7 64 bits - Intel core i7 870 - 3,30 Ghz, - 12 Gigas Ram - GTX 660 + GTX 650 Ti
http://www.garquitectos.es
http://garquitectos.wordpress.com/
Moving the Setup window or the Viewport?I has some crash when the plugin is "voxeling" and I try to move the octane palette at the same time.
- Garquitectos
- Contact:
The setup window...
Are you using a single graphics card for both rendering and as your Window display adapter? Or do you have 2 or more adapters in your PC?The setup window...
[EDIT: I would be interested yo know if this can be reproduced. I don't have any scenes which take long enough to voxelize to be really able to test it].
- Garquitectos
- Contact:
I hava a Radeon 5750 for windows display and a GTX 650 Ti dedicated to Octane. If you can I can send you (wetransfer) a model that I made for a contest (with no luck) to play with it.face_off wrote:Are you using a single graphics card for both rendering and as your Window display adapter? Or do you have 2 or more adapters in your PC?The setup window...
For the quality of work you are producing, you deserve a better carda GTX 650 Ti dedicated to Octane
That would be great - thank you - I can try to reproduce the issue then.If you can I can send you (wetransfer) a model that I made for a contest (with no luck) to play with it.
[EDIT: I have noticed even with 2 graphics cards, ArchiCAD can slow down whilst rendering if you are in OpenGL mode. Changing to Internal Renderer speeds everything up again.]
- Garquitectos
- Contact:
I tell to my wife that she must buy a better card but...face_off wrote:For the quality of work you are producing, you deserve a better carda GTX 650 Ti dedicated to Octane
Archicad is not too much slow in my machine, at least without solar shadows.
I will send you the .PLA
I just found a large scene someone had sent me and loaded 10 times moving the setup window, but could not get a crash. It would be interesting to see if you can reproduce it on your PC before sending the file.I will send you the .PLA
- Garquitectos
- Contact:
I have desactivated the "hardware acceleration in 2d" in the archicad enviroment and the "crash" have gone. I think that the crash appear when I put the radeon like primary video card... until this I only have the gtx 650 ti, and no crash.
New test version posted - http://render.otoy.com/forum/viewtopic.php?f=56&t=32899.
