Just test an animation, and cannot get these "poke through" off completely.
the smoothing and interaction iteration is a bit long. I have uncheck all live update and base shape.
For still image it's OK. But for animation I notice that the plugin get the info too early, (the collision iteration process is not finished on the DS viewport (progress bar do not get to 100%), and then some "poke through" get visible.
@linvanchene, could you just do a simple animation with your figure to confirme my issue ? thanks
Poke through issues in Octane renders?
Moderator: BK
i can not directly confirm this, but can say it might be easily possible that this happens; the plugin iterates through all nodes, tells them to finalize their geometry, and afterwards collects the geometry. i had several circumstances were similar things happened, so this might be the case here too. means i need to find a way to make sure, ds has really finished all geometry changes when the plugin starts to transfer it to octane; i will check back with daz to see if there is any sort of event, that will tell this for sure...itou31 wrote:Just test an animation, and cannot get these "poke through" off completely.
i really love to read such sentencesitou31 wrote:thanks t_3,
the more I discover your plugin, the more I love it !!
No more transfer to 3dsmax for animation....
just head away form the current issues (until i have resolved them,)so the love can grow undisturbed
I just update with the build 2121, something better but not perfect at some keyframe, the "poke thru" get back, due to more time to DAZ for smoothing. I can see the progress bar and viewport from DAZ not get full update, but the render viewport of octane is already done !?
I7-3930K 64Go RAM Win8.1pro , main 3 titans + 780Ti
Xeon 2696V3 64Go RAM Win8.1/win10/win7, 2x 1080Ti + 3x 980Ti + 2x Titan Black
to be honest, there wasn't yet a fix for this (i just missed to write it into the "todo" list in the update info post)... a hopefully final fix is to expect for the next update, which should arrive around the weekend...itou31 wrote:Hi,
some update about this: what the plugin might do - and what you may already test (if you like to help) is, to activate the "interactive update" for all nodes that have smoothing applied. in theory this should let the plugin already now wait until all the smoothing is done; it would be also interesting to know if and how this works for collisions...itou31 wrote:Hi,
ps; there is next to no documentation about these ds4 features (i mean their use through the daz sdk), so i can make good use of any findings in that area...
Hi t_3,
Yes ! "interactive update" is the key. The plugin now "wait the DAZ viewport" .
thanks for the tip !
Ok, let's play more in deep with the plugin ...
great! thanks for checking that out - this will be included into the geometry building process for animations, so you don't have to care about changing it by hand...itou31 wrote:Hi t_3,
- linvanchene
edited and removed by user
