OctaneRender® for Maya® v1.02b beta [OBSOLETE]
RickToxik
Don't get me wrong NEWLOGIC, I am not blaming you lol... I'm having a hard time too to make HDR lighting without noise. Can't wait to try the importance sampling, I have seen very good comparisons on the Otoy facebook page.
There is also a feature I would like very much, but I don't know if it's up to the octane engine team or the maya plugin.
It would be very useful if we could have a local LiveDB version cached in our computer. My computer is always offline except for registering updates, it needs to be offline but I would like to use the LiveDB library.
NEWLOGIC
those octane rendered images from the Otoy facebook page look so realistic(especially the one with human face),must admit i was really impressed.For a second,I even thought it was someone's picture taken by camera )) But so far, it's a great tool for rendering models in standalone version, let's hope soon we could breathe life into those models and render them in HDR environment using the octane plugin in Maya )) Thanks to Jimstar for doing really important work.
arh-osa
Lack of UI feature for Octane nodes: there is no Extra Attributes layout, so when I add custom attributes I get some problems with arrangement of the controls.
SketchUp Pro 8/ Maya 2012 / W7 64bit / Intel i7 870 / 8GB / 2*GeForce gtx 680 4GB
arh-osa
I found some bugs in emission node:
- When I change geometry type to Movable proxy or Scatter, Octane considerably reduces the intensity of light.
- I try to control emission attribute (in my case Power) with expression. When I try to delete expression connected to Octane Emission node (rightclick attr or in Hypershade), Maya deletes the Emission node too.
arh-osa wrote:- When I change geometry type to Movable proxy or Scatter, Octane considerably reduces the intensity of light.
It's known engine issue, which was already discussed in some of the plugin threads... This behaviour can't be changed from the plugin side...
jmfowler
Jimstarr - is it possible to have the animation : camera mode also update keyframed variables for the camera?
IE i have key framed the max samples override but I have noticed the camera mode didn't update when rendering from the command line. It would be greatly efficient to have the camera mode update all the variables contained for the camera.
RickToxik
NEWLOGIC wrote:Does anyone have problem with noise when rendering scene using HDR image in Maya 2013?Did you come up with solution?
I have found something very basic NEWLOGIC. If you're using 32 bit HDRIs (exr, hdr), make sure you set the gamma of the octaneimagetexture to 1 instead of the default 2.2. It will clean a LOT of the noise very fast. You can validate that you are in the right gamma value by checking "keep environment" in the render settings and make a quick render of the hdr in your viewport. (I'll post this into your other thread too for the search function of the forum).
NEWLOGIC
RickToxik,
That really worked,I went further and reduced the gamma down to 0.5. I balanced the hdr texture power as well and it looks a lot better now.Thanks for the tip.
I really appreciate your help.
RickToxik
well it solved my problem too, so you guess that I am as happy as you are :lol:
RickToxik
Hi! I'm trying to batch render an animation with some (animated) paint fx converted to polys. Everything works fine when I launch an IPR or a render frame, but it seems octane has some issues with the UVs of my paint fx, as shown in the MayaRenderLog.txt. When I hide the paintfx the batch render works.
I'll try to bake the animation to see if it changes anything.
Octane data types are registered...
Octane nodes are registered...
Octane settings store is registered...
Octane settings instance is created...
Octane camera is registered...
Octane tool shelf commands are registered...
Starting Octane engine...
Octane plugin is activated.
Octane UI is registered...
...done in 0 min. 23 sec.
File read in 24 seconds.
Result: //ERIC-I7920/Maya/MG/Drop/Drop 1 edit 13__5992.mb
Octane: Starting in batch mode...
Octane: starting animation of frame 100...
Octane: Scene scale factor: 0.01
0:00 Device "1:  GeForce GTX 570 (compute model 2.0)" is ENABLED
0:00 Device "2:  Quadro FX 3800 (compute model 1.3)" is DISABLED
0:00 Octane kernel set: Direct Lighting
0:00 Octane engine: creating meshes...
0:00 Gathering Mesh objects data...
Octane: Object "pSphereShape1Orig" is not visible, skipping...
0:00 Setting Mesh data of mesh: pSphereShape1
****************************** MESH DATA ******************************
Number of vertices: 6370
Number of normals: 6370
Number of UVs: 8660
Number of polygons: 6368
Number of vertex indices: 25472
Number of normal indices: 25472
Number of UV indices: 25472
Number of material indices: 6368
0:00 ...done setting Mesh data in 0:00
0:00 Voxelizing...
0:00 ...voxelized in 0:00
0:00 Setting Mesh data of mesh: pPlaneShape1
Number of vertices: 4
Number of normals: 4
Number of UVs: 4
Number of polygons: 1
Number of vertex indices: 4
Number of normal indices: 4
Number of UV indices: 4
Number of material indices: 1
0:00 Voxelizing...
Error: Octane: Error getting UV IDs of object: "floweringPea1MainShape (UV set "map1")
Error: Octane: Error getting UV IDs of object: "floweringPea1LeafShape (UV set "map1")
Error: Octane: error allocating the memory for Object "floweringPea1LeafShape"
Error: Octane: Error mesh export. Octane render stopped.
Return to “Autodesk Maya”
