Soft2Octane 3.03 [Obsolete]
Autodesk Softimage XSI (Developed by Face)
face
Here is a quick fix for x64.
Replace the Soft2Octane_x64.dll from the C:\Users\XX\Autodesk\Softimage_XXX\Addons\Soft2Octane\Application\Plugins\bin\nt-x86-64 folder with the one from the zip file.
face
http://vimeo.com/user2509578
Chris_TC
Cool, thank you! I'll try it out and let you know.
Chris_TC
The frames appear to finish correctly, however the plugin does not seem to advance the timeline. It just renders the first frame of the animation over and over.
SetValue("Soft2Octane.start", 50, null);
SaveScene();
// INFO : Starting Renderengine
face
Sorry, my error.
It was build 5min. before my trip to work ;)
face
Soft2Octane.zip
(201.07 KiB) Downloaded 499 times
Chris_TC
No problem, I appreciate the quick help.
The plugin seems to work now. I will let it run over night and see what happens :-)
Chris_TC
The machine has now rendered for 24 hours non-stop without any problems. The plugin works perfectly, thanks again! :)
PeterCGS
I got two different ICE clouds each with its own Octane Scatter.. But I only get one them actually writing out a .obj/.scv file and the other one is ignored? Is there any workaround for this? Seems also my particles are now flipped in the direction :O
/regards Peter K
Win7, i7 980 Hexacore, 24GB RAM, 3xEVGA SC 670 GTX 4GB
face
The flipped issue is solved but i don´t know why one pointcloud is ignored.
If the Set Octane Scatter compound is set in each cloud to true, it should export a csv file for every cloud.
Have test it with a duplicated cloud where the second has an other shape and an other speed.
Try to use this dll for x64.
face
Soft2Octane_x64.zip
(201.18 KiB) Downloaded 454 times
Amplitude
Hi Face,
I'm having some problems installing this latest version on Softimage 2011. The dll seems to be the cause (appears in red in the plugin manager). I tried to replace the dll with the one you're providing on page 2 of this thread but doesn't work either.
When I try to access the plugin through the toolbar menu I get the following error:
Application.SIAddProp("Soft2Octane", "Scene_Root", "siDefaultPropagation", "Soft2Octane", "")
# ERROR : Invalid procedure call or argument: 'SIAddProp' - [line 18]
# ERROR : (Microsoft VBScript runtime error)
# ERROR : [16] (null)
# ERROR : [17] function gen
# ERROR : >[18] SIAddProp "Soft2Octane", "Scene_Root", siDefaultPropagation, "Soft2Octane"
# ERROR : [19] inspect
# ERROR : [20] end function
Can you help me?
Win7 Pro x64 | GTX 770 2GB + GTS250 512Mb | Intel Xeon i7 4x 3.4ghz | 16 GB ECC Mem | Intel SSD 520 | Dell 27"
SOFTIMAGE l 2011 + OCTANE V1.20
face
When the dll is red, they isn´t loaded.
Have you installed the Microsoft Visual C++ 2010 x64/x86 Runtimes and Redistributeables?
face
Return to “Autodesk Softimage XSI”
