Nildo
Unfortunately I can't do anything with it. You have to use old version to finish you movie or try to reduce saturation in imager settings.nildoe wrote:Karba is there a way to the legacy colors with this new version? i so much wanna use it to render my movie, but colors are so different, although MUCH better, i have already rendered about 4MINUTES worth of 720p footage with the old 3.00d.
abstrax wrote:Did you update to the latest NVIDIA driver (306.23)? If not, please do that and check if the problem persists.be_fast wrote:Thank you, its actually faster, I tested and surprised that prev 3.01 took 2m51s to render a frame when 3.02 took 2m30sec which is great. But I already found UV bug
Max 2012 x64, in 3.01 this model was fine, it is fine in the viewport and any other render
Marcus
nope...drag and drop...nildoe wrote:Imager does not help...please is there a way to use multiple octane versions in one max install?
Nildo
