How to reduce the bounce?jmfowler wrote:Im rendering a FULL HD animation of an interior pool scene atm - basically one of the hardest setups for an unbiased render-er - I found the biggest help to get a good image was
1) reduce bounce ( max depth ) to 8 as posted above. 8 is enough and will speed up render.
2) I'm assuming your using PMC as your render kernel.
3) Take max rejects down to 100 ( from 500 ) this will 'bias' your render more but it will clean it up faster so you can either have more samples per time or reduce the samples for any set time.
4) adding some lights on in the kitchen with definitely make a difference - if you want to make that choice.
5) check that you dont have any pure white surfaces using RGB 255,255,255
good luck!
Kitchen
- lillian reeves
- Contact:
If you are remodeling your kitchen then check out these Kitchen Cabinets for Sale.
