Display Problem after reinstallation
so probably the issue doesn't come from the c4d side.... maybe cuda drivers?
roeland
Can you export an OBJ file and post this file?
Roeland
Murd0ck
i7 - 3820 @4,4Ghz | 2x GTX770 4Gb + 1x GTX 780TI 3Gb | Win10 64 Bit | 16Gb Ram
roeland
I can render that OBJ file fine if I import it as millimeters, but not as meters (in the second case the object is a few kilometers accross). So again, make sure your geometry is imported at the correct scale.
The missing triangles are caused by a problem with very big axis-aligned planes, which may be fixed in a later release of Octane.
Roeland
Murd0ck
Aaahhh, works fine with Milimeters.
First i thought, what the hell, where are my Objects.
After Target and Camera reset i found them :D
Thanks for ur great help ;)
