Displacement map support Please!
James
one thing regarding lights...
I have modelled some basic theatre and TV lamps that have a 'bulb' inside them and lenses so that they really do work like a real light... The results should in theory be realistic...
Kubuntu 9.04 | Nvidia Gainward 9500 GT | Intel Core2 Quad 2.40 Ghz | 4 GB RAM
[gk]
right, I was actually thinking about this today.
Went home from work for some hours to watch some tv and get some food, anyways when i got back one my the bosses came around with 2 physical models in 1:50 of some sets, so i hammered up 2 800w fressnel lamps in a small intermistic set one key and one fill with umbrella.
I need to get a RED head set though, the fressnels are killing me, so heavy and impractical to move around.
Amiga 1000 with 2mb memory card
James
Fresnels are relatively light compared to some Profile (typical spot light) lights in theatre.
Garrick
PhilBo wrote:To get a spot light in an unbiased environment, you actually have to model a simple spot light and put an element in it that you would give an emitting material and crank up the power.
Then how does one make an emitting material in octane to mimic a light source?
Vista 64| 660 GTX | 6600 Quad | 8GB DD2|Maya 2011
Amplitude
Hey Garrick,
IMHO either by modeling the actual geometry, or by using IES profiles attached to the light source.
Win7 Pro x64 | GTX 770 2GB + GTS250 512Mb | Intel Xeon i7 4x 3.4ghz | 16 GB ECC Mem | Intel SSD 520 | Dell 27"
SOFTIMAGE l 2011 + OCTANE V1.20
Garrick
Thanks for the reply,
Where do you import IES file with in the Octane program?
Because so far I haven’t found any import options for that file format.
I have a spotlight modeled with materials, that is pointing to a ground plain.
Now how would I get the light bulbs material to emit light or is their another way to do this?
[gk]
mm?
If you look around on the forum you will see that there is no material light yet, it might be implemented in the next point beta as in 2.3. Which isnt the one just around the corner.
However you can bake the Light to you materials in your host app,as anyone would do it at this point.
gristle
...but cannot make luminous(yet), so of limited value.
Is IES support on the roadmap?
I presume not, because there won't be traditional lights as such.
Win 10. Threadripper 1920X 32gb Ram GTX 1080Ti GTX 980Ti 2xGTX 780
http://ajdesignstudio.co.nz/
[gk]
I dont see that happen, it would be some ugly hybrid for sure.
You need a material that sticks out inverse quare and thats it,fry intensity up or tone it down.
This is what will be done first.
-mads
Garrick
If anyone from Refractive software would care to answer my last posting this would help me.
