no, the memory will stay the same as one card.InfoBrain wrote:So when multi GPU support is available 2 X 470 would be better than a single 480, nearly twice the cores and memory from both cards would be available for rendering 3GB+/- correct? Or will we still only be able to use memory from 1 card and just the additional cores from the second GPU
I was going to order a single 480 today, my PS is only 750 and will only support one and I was going to use one of my 9800gt's for OS, but then I found Newegg has a special combo "today only" 2 x EVGA 470 + Corsair 950 PS for $709.98 US. http://www.newegg.com/Product/ComboDeal ... mbo.390415
So for less than $200 more I can have almost 2 times 480 with a 950 PS, but can anyone confirm that a 950 PS is going to be enough power to support 2 x 470???
if you use more than one GPU at the same time with 2.2, you can have available for use, the memory size of the smallest of the GPUs you put in it.
if you render with 2x GTX470 you will have less memory than with one GTX480
Radiance
