What PSU do i need to power up 4 GTX580/590s?
sli isn't needed for octane (in fact it should be turned off). octane is able to use as much cards/cuda cores available - just put in 8 590s, and octane will use all 8192 coresKaroBastardKiter wrote:Thanks Refracty
I just got this reply from a pc workshop
"It is not possible to run 3 x GTX590 cards in TRI-SLI, as each card is made with 2 x GTX580’s. So 2 GTX590 cards are 4 x GTX580 in Quad SLI. 3 cards would be 6 x GTX580’s which won’t work. Would you like a quote with 2 x GTX590’s instead?"
does it maybe imply that I don not have to go for a TRI-SLI configuration?
Cheers
maybe. don't know about windows, but for linux the driver supports 16 devices in theory. afaik this is also limited by the mainboard bios, so it'll always be a game of chance.nildoe wrote:I dont think you would be able to run 8 590 even if you had the money for it, im not sure but i think i read somewhere that the maximum gpus supported by nvidia or windows were 8... So 8 590 would in fact be 16 no? Since they are actually dual gpu cards?
Nildo
