tomorrow our new stoves are coming :)
- understand
put another barbi on em
Win 8.0 64-bit | Gainward 460 GTX 2048mb (driver: latest) | Phenom 965 3.4ghz 140w | 12GB
Win 8.1 64-bit | EVGA 780ti Superclocked 3072mb (driver: latest) | i7 4930k 3.4ghz | 32GB
Win 7 64-bit Bootcamp | 650M 1GB (driver: 327.23) | i7 2.7ghz | 8GB
Are those steaks ready? I'm in the mood for some midnight snack. "droooooooooooools"radiance wrote:i got some big, raw t-bone steaks to bake on them
Radiance
Dual Lindenhurst single core Xeon 3.6Ghz with Hyperthreads, 8GB DDR-2 ECC, Geforce GTX 260
Dual Xeon 5680 3.2Ghz with Hyperthreads, 24GB DDR-3 ECC, Quadro 4800 & GTX 480
Well they aren't 480's, but my 470's showed up today. Initial tests against the gts250 I've been using the last 2 months are great. On a highly reflective scene I'm getting about triple the performance. Much higher on the simpler chess scene. Standard idle noise is actually much quieter then the gts250, and way less then my old 8800gt. You will notice it when it starts going full bore, but even then it is still not too bad. These are just base models of the gtx470's (1 EVGA and the other is MSI). My motherboard here only has a single PCIe slot, so I will try them at my work next week in SLI (once multi-GPU is supported).
System 1: EVGA gtx470 1280Mb and MSI gtx470 1280 in Cubix Xpander for Octane, AMD 945, 4Gb Ram
All systems are at stock speeds and settings.
multi-gpu does not use SLI and in fact you will have to turn off SLI to use multiple GPUs with 2.2havensole wrote:Well they aren't 480's, but my 470's showed up today. Initial tests against the gts250 I've been using the last 2 months are great. On a highly reflective scene I'm getting about triple the performance. Much higher on the simpler chess scene. Standard idle noise is actually much quieter then the gts250, and way less then my old 8800gt. You will notice it when it starts going full bore, but even then it is still not too bad. These are just base models of the gtx470's (1 EVGA and the other is MSI). My motherboard here only has a single PCIe slot, so I will try them at my work next week in SLI (once multi-GPU is supported).
Radiance
I'm an idiot. I knew that, but have been pretty sleep deprived with work and other projects., my brain has been a little burnt out.
