MY first Octane Render
omorenof
This is great really. I didn´t expect to be this easy to pull out an image from Octane.
There is too much still for me to learn i guess. I would like some constructive feedback from the community, i will appreciate that. Modeled in Blender 2.63a, used the Octane plugin, and most of the materials where from the Live DB.
This is a WIP, I´ll finish the image and post it as a finished render.
For the time been i appreciate any feedback.
How to get rid of the noise and some white artifacts i get in the image?
My first render. -omorenof
Win 7 64 Bit, Xeon W3565 4cores 8threads @3.20GHz, 24 GB RAM, Geforce GTX 590 & 680, Blender (latest build)
Daniel
Drag that to the left and watch the noise disappear!
Only use it once you've let the render cook for a while, otherwise you end up with a blurred image.
Core i7 950 @3.07GHz | GTX 460 2GB | 12GB RAM | Window 7 x64
glimpse
Nice start! How to cut times and lower noise? =) well it depends on Your setup:
* firstly check which kernel works best for Your needs, pmc or pt =)
* then try adding portal - this sometimes speeds up the rendering process a bit. =)
omorenof
Thanks Daniel.
It worked. I´ll post the final image once its done. thank you.
paoloverona
really nice image!
for my opinion the window lacks of details (in real there are no details at all :lol: ) and maybe a better image as background is needed, the last suggestion is for the couch material that I think it's too glossy.
I'm sure that with little more effort it will come out a great render
intel i7 3820 3.6GHz, 16Gb 1600Hz, windows 7 professional 64bit, gtx 580 3Gb x2, Octane 3dsMax 2.58
Return to “Works In Progress”
