Gems .
buffalowingmedia
Thank You Very Much :)
Core I7-2600, 8GB DDR 3, GeForce 440 GT 3GB DDR3, Windows 7 Home Premium
sean1
Thanks !
Win 7_ 64 | Quadro2000 / Geforce GTX690 | Quad 2.66GHz | 8GB |Rhino V5 64Bit
mlody47
no problem :)
i7 2600K + 2X gtx 580 + GTX 560 Ti + 8gbram + Win7 +
AUTODESK SOFTIMAGE 2012
www.behance.net/mlody47
DayVids
Your guys primary issues are as a result of the "cuts" of the gems.
You need more cuts in the gems to reflect light more.
It's a bit exaggerated there but I have some less pronounced ones as well.
See here for one that's not quite as pronounced.
CPU - i7-950 3.06 Ghz, 24GB Ram, Win7 x64, 2 display monitors, GeForce GTX 580 3GB Classified. I'm glad to say I LOVE OCTANE!
sean1
Second render of Gems . Changed the IOR and used a HDRI with black and white, no post work .
Comments please :
Apologies ! ( new here ) . I should have put up in WIP , but I don't want to break thread now.
mlody47
DayVids wrote:Your guys primary issues are as a result of the "cuts" of the gems.
ofcourse NOT ! Every gem is different .... it depends on what gem You are aiming for....
there are like 100 ways of cutting the Diamond... and its not only the one You have :)
ROUBAL
The main problem I see is that your three gems have diamonds cuts. Each kind of gem has several kinds of cuts, and they are studied to give the best refractions inside the gem to allow the light come out of it after some internal reflections, according to the specific Indice Of Refraction of the gem.
I think that you will not see any esmerald with that kind of cut. Esmeralds generaly have less faces and a large table.
Result of a quick a google search :
http://www.google.fr/search?hl=fr&safe= ... a=N&tab=wi
DayVids
mlody47 wrote:ofcourse NOT ! Every gem is different .... it depends on what gem You are aiming for....
WHHHHHAAAAAAAAAAAATT???? You mean I don't know everything :P
My apologies if I sounded like a pompous (ahem). I just assumed that since they were diamond cuts, they were intended to have a high degree of reflection and light bounces. You guys are indeed quite right, lots of diamonds have lots of different cuts and varried gemstones usually have a most common appearance.
I like the 2nd render Sean.
mlody47
hahaha ... Idont know everything either :) but I remember when I was researching Diamonds.... that they have similar patterns but not exactly the same :)
Return to “Works In Progress”
