Hey,
- I was hoping the same thing about the refreshing the render view. Like I said before the frame rate shows, but there is no rendering happening.
- I am going to post this just incase some could find something in this report. Just for your info I did also push reset camera view button and it crashed from there.
Process: octane_demo [880]
Path: /Applications/OctaneRender Demo 1.024 beta2.46b.app/Contents/MacOS/octane_demo
Identifier: org.refractivesoftware.octanerender
Version: 1.024 (1.024)
Code Type: X86 (Native)
Parent Process: launchd [209]
Date/Time: 2011-05-20 09:28:44.141 -0700
OS Version: Mac OS X 10.6.7 (10J869)
Report Version: 6
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 ...activesoftware.octanerender 0x004ef39a RenderManager::ControlResetCamera() + 154
1 ...activesoftware.octanerender 0x003840ae WorkPaneComponent::buttonClicked(juce::Button*) + 1390
2 ...activesoftware.octanerender 0x001a0ce3 juce::Button::sendClickMessage(juce::ModifierKeys const&) + 243
3 ...activesoftware.octanerender 0x00247c0d juce::Component::internalMouseUp(int, int, int, long long) + 1101
4 ...activesoftware.octanerender 0x0024b807 juce::ComponentPeer::handleMouseUp(int, int, int, long long) + 1127
5 ...activesoftware.octanerender 0x0024bc82 juce::NSViewComponentPeer::redirectMouseUp(NSEvent*) + 658
6 com.apple.AppKit 0x908b6cf8 -[NSWindow sendEvent:] + 5693
7 com.apple.AppKit 0x907cf817 -[NSApplication sendEvent:] + 6431
8 com.apple.AppKit 0x907632a7 -[NSApplication run] + 917
9 ...activesoftware.octanerender 0x0020a38b juce::JUCEApplication::main(int, char**, juce::JUCEApplication*) + 667
10 ...activesoftware.octanerender 0x0003c308 main + 88
11 ...activesoftware.octanerender 0x0003c266 start + 54
Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x9880e922 kevent + 10
1 libSystem.B.dylib 0x9880f03c _dispatch_mgr_invoke + 215
2 libSystem.B.dylib 0x9880e4f9 _dispatch_queue_invoke + 163
3 libSystem.B.dylib 0x9880e29e _dispatch_worker_thread2 + 240
4 libSystem.B.dylib 0x9880dd21 _pthread_wqthread + 390
5 libSystem.B.dylib 0x9880db66 start_wqthread + 30
Thread 2:
0 libSystem.B.dylib 0x98816046 __semwait_signal + 10
1 libSystem.B.dylib 0x98815d02 _pthread_cond_wait + 1191
2 libSystem.B.dylib 0x98815855 pthread_cond_timedwait$UNIX2003 + 72
3 ...activesoftware.octanerender 0x0006ad0e juce::WaitableEvent::wait(int) const + 190
4 ...activesoftware.octanerender 0x0030c472 juce::InternalTimerThread::run() + 674
5 ...activesoftware.octanerender 0x002033c9 juce::Thread::threadEntryPoint(juce::Thread*) + 649
6 ...activesoftware.octanerender 0x002034b6 juce::threadEntryProc(void*) + 70
7 libSystem.B.dylib 0x988157fd _pthread_start + 345
8 libSystem.B.dylib 0x98815682 thread_start + 34
Thread 3: com.apple.CFSocket.private
0 libSystem.B.dylib 0x98807066 select$DARWIN_EXTSN + 10
1 com.apple.CoreFoundation 0x921eec83 __CFSocketManager + 1091
2 libSystem.B.dylib 0x988157fd _pthread_start + 345
3 libSystem.B.dylib 0x98815682 thread_start + 34
Thread 4:
0 libSystem.B.dylib 0x987eb264 strlen + 36
1 libSystem.B.dylib 0x987f5c00 __vfprintf + 6630
2 libSystem.B.dylib 0x98808199 asprintf + 382
3 com.apple.CoreFoundation 0x92216c38 CFLocaleCreateLocaleIdentifierFromComponents + 568
4 com.apple.CoreFoundation 0x92216894 __CFCalendarCreateUCalendar + 164
5 com.apple.CoreFoundation 0x922166f2 CFCalendarCreateWithIdentifier + 530
6 com.apple.CoreFoundation 0x92246ee7 __CFLogCString + 999
7 com.apple.CoreFoundation 0x92246aee _CFLogvEx + 334
8 com.apple.Foundation 0x983d27b0 NSLogv + 143
9 com.apple.Foundation 0x983d271f NSLog + 27
10 com.apple.AppKit 0x9082fb40 -[NSOpenGLContext initWithFormat:shareContext:] + 200
11 ...activesoftware.octanerender 0x00155390 juce::OpenGLContext::createContextForWindow(juce::Component*, juce::OpenGLPixelFormat const&, juce::OpenGLContext const*) + 768
12 ...activesoftware.octanerender 0x001c3d39 juce::OpenGLComponent::makeCurrentContextActive() + 489
13 ...activesoftware.octanerender 0x00387e8b ThreadedGLComponent::run() + 347
14 ...activesoftware.octanerender 0x002033c9 juce::Thread::threadEntryPoint(juce::Thread*) + 649
15 ...activesoftware.octanerender 0x002034b6 juce::threadEntryProc(void*) + 70
16 libSystem.B.dylib 0x988157fd _pthread_start + 345
17 libSystem.B.dylib 0x98815682 thread_start + 34
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x0500ba00 ebx: 0x004ef30e ecx: 0x004ef300 edx: 0x00000000
edi: 0x04e641e0 esi: 0x000007e3 ebp: 0xbffff2a8 esp: 0xbffff260
ss: 0x0000001f efl: 0x00010246 eip: 0x004ef39a cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
cr2: 0x00000000
Difficulty getting the render view to work.
So just to confirm Octane should work ok on my system with the following card?
Chipset Model: NVIDIA Quadro 4000
Type: GPU
Bus: PCIe
Slot: Slot-1
PCIe Lane Width: x16
VRAM (Total): 2048 MB
Vendor: NVIDIA (0x10de)
Device ID: 0x06dd
Revision ID: 0x00a3
ROM Revision: 3581
Again the software opens fine with no errors.Only the render viewport is empty.
Type: GPU
Bus: PCIe
Slot: Slot-1
Device ID: 0x06dd
Revision ID: 0x00a3
ROM Revision: 3581
Windows 7 Pro 64bit, 16 GB Ram, Intel Core I7 3.4GHz, Dual Gtx 580 cards
When you start rendering does it actually increase the samples per pixel? Or does nothing happen. Could you please post a screen shot of the CUDA device information panel under File -> Preferences...?
Marcus
Marcus
I know its been a while since I last heard anything, but I figured it out on my own why octane was not working. The process of installing is very important. Yet after installing it still didn't work. I think, because of trial and error over a few months, that the update for 10.6.7 updates on a mac had a bug. with the drivers. You need to do a repair with mac install disk. The error that came with the nVidia update and newest Mac update lost some files. Do a disk repair from the CD. The latest cuda and nVidia update don't work so you haft to go back to a later date. But I ran into a problem because the update was older. If you open the folder and show package content you can install them individually. After doing so and then adding the new nVidia updates again it worked. I have purchased octane since the demo works.
I find it remarkable with the help I received, that my machine runs both a GeForce 8800 GT and Quadro 4000 on my mac. I use my GeForce to run my monitor and my work horse Qudaro card to do the heavy lifting. I just want to sent a message to mac users that it can be done.
The website below will give you the older version the drivers for nVidia
http://www.nvidia.com/content/DriverDow ... p?url=/Mac
Thanks for inquiry from the past.
Number28,
http://www.number28.org
Number28,
