[FREE] Custom Octane python api for c4d
WDH
Hi Octane community!
This is my free python api hleper for third-part render engines. You can find it on my github : [renderEngine](https://github.com/DunHouGo/renderEngine)
It contains Octane/Redshift/Arnold api, and Octane is ready to beta now.
You can operate videopost/aovs/material(nodes)/objects/tags in python.
Take a look at the Octane examples. Hope it can helps!
If you like it, please hit me a star and very welcome for your contributions.:blush:
# Octane
This is a custom api for Octane Render in Cinema 4D, which is also wiil contains in 'boghma' library.
All the boghma plugins and boghma library is FREE.
## Installation
To use this library, you have two options:
1. Download the source and import it to your Cinema 4D
2. (**Not Ready Now**) You can also download [Boghma Plugin Manager](https://www.boghma.com/) and install any plugin, the boghma lib will auto installed.
# Limit
Due to otoy use a custom userarea for the node editor, and don't support python. We can not get the selection of the node edtor, so it is not possible to interact with node editor.
# Class Presentation
## octane_id
#### This Class contains unique ids for octane object, and name map of aovs.
## octane_helper
#### This Class contains the functions for the library. And it has some children Classes.
- __Functions(functions)__
- __VideoPostHelper__
- __AOVData__
- __AOVHelper__
- __MaterialHelper__
- __SceneHelper__
### octane Class/method highlighted:
#### This Class contains methods for the library. It has the following methods:
- __GetRenderEngine__ : Return current render engine ID.
- __GetVersion__ : Get the version number of Octane.
- __OpenIPR__ : Open Live Viewer.
- __OpenNodeEditor__ : Open Node Editor for given material.
- __AovManager__ : Open aov Manager.
- __TextureManager__ : Open Octane Texture Manager.
### AOVData:
#### Octane AOV dataclass structure
- __aov_shader__: c4d.BaseShader
- __aov_enabled__: bool
- __aov_name__: str
- __aov_type__: c4d.BaseList2D
- __aov_subdata__: list
### AOVHelper Class/method highlighted:
- __get_aov_data__ : Get all aov data in a list of BaseContainer.
- __get_all_aovs__ : Get all octane aovs in a list.
- __get_aov__ : Get all the aovs of given type in a list.
- __read_aov__ : Get aov data in a list of AOVData Class.
- __print_aov__ : Print main info of existed aov in python console.
- __create_aov_shader__ : Create a shader of octane aov.
- __add_aov__ : Add the octane aov shader to Octane Render.
- __remove_last_aov__ : Remove the last aov shader.
- __remove_empty_aov__ : Romove all the empty aov shaders.
- __remove_all_aov__ : Remove all the aov shaders.
- __remove_aov_type__ : Remove aovs of the given aov type.
- __get_custom_aov__ : Get the custom aov shader of given id.
- __add_custom_aov__ : Add the custom aov shader of given id if it not existed.
- __get_light_aov__ : Get the light aov shader of given id.
- __add_light_aov__ : Add the light aov shader of given id if it not existed.
### NodeHelper Class/method highlighted:
- __GetAllNodes__ : Get all nodes of the material in a list.
- __GetNodes__ : Get all nodes of given type of the material in a list.
- __RefreshTextures__ : Refresh all the Texture shader.
- __ResetCompression__ : Reset all the texture shader compression.
- __AddShader__ : Add a shader to the material of the given type and slot.
- __AddTransform__ : Add a Transform shader to the given slot(option).
- __Addrojection__ : Add a Projection shader to the given slot(option).
- __AddMultiply__ : Add a Multiply shader to the given slot(option).
- __AddSubtract__ : Add a Subtract shader to the given slot(option).
- __AddMathAdd__ : Add a MathAdd shader to the given slot(option).
- __AddMix__ : Add a Mix shader to the given slot(option).
- __AddInvert__ : Add a Invert shader to the given slot(option).
- __AddFloat__ :Add a Float shader to the given slot(option).
- __AddRGB__ : Add a RGB shader to the given slot(option).
- __AddImageTexture__ : Add a ImageTexture shader to the given slot(option).
- __AddCC__ : Add a Color Correction shader to the given slot(option).
- __AddGradient__ : Add a Gradient shader to the given slot(option).
- __AddFalloff__ : Add a Falloff shader to the given slot(option).
- __AddDirt__ : Add a Dirt shader to the given slot(option).
- __AddCurvature__ : Add a Curvature shader to the given slot(option).
- __AddNoise4D__ : Add a Maxon Noise shader to the given slot(option).
- __AddNoise__ : Add a Octane Noise shader to the given slot(option).
- __AddTriplanar__ : Add a Triplanar shader to the given slot(option).
- __AddDisplacement__ : Add a Displacement shader to the given slot(option).
- __AddBlackbodyEmission__ : Add a Blackbody Emission shader to the given slot(option).
- __AddTextureEmission__ : Add a Texture Emission shader to the given slot(option).
- __AddTextureTree__ : Add a Texture + Color Correction + Gradient shader tree to the given slot(option).
### MaterialHelper Class/method highlighted:
- __CreateBasicMaterial__ : Create an Octane Basic(classic) material of given type and name.
- __CreateComposite__ : Create an Octane Composite material of given type and name.
- __CreateStandardMaterial__ : Create an Octane Standard Surface material of given type and name.
- __InsertMaterial__ : Insert the material to the document.
- __Refresh__ : Refresh thumbnail.
- __SetActive__ : Set the material active in the document.
- __SetupTextures__ : Setup a pbr material with given or selected texture.
- __UniTransform__ : Add a Transform node to all the Image nodes.
### SceneHelper Class/method highlighted:
- __add_hdr_dome__ : Add a texture (hdr) dome light to the scene.
- __add_rgb_dome__ : Add a rgb dome light to the scene.
- __add_dome_rig__ : Add a HDR and visible dome light folder.
- __add_light__ : Add an Octane light to the secne.
- __add_light_texture__ : Add textures to given Octane light tag.
- __add_ies__ : Add an Octane ies light to the secne.
- __add_gobo__ : Add an Octane gobo light to the secne.
- __add_sun__ : Add an Octane sun light to the secne.
- __add_light_modifier__ : Add some modify tagsto given Octane light tag.
- __add_object_tag__ : Add an object tag to the given object.
- __add_objects_tag__ : Add object tags to the given objects(enumerate id).
- __add_custom_aov_tag__ : Add an object tag of given custom aov id to the given object.
- __add_camera_tag__ :Add an camera tag to the given camera.
- __add_scatter__ : Add a scatter object of given generator_node and scatter_nodes.
- __add_vdb__ : Add a vdb loader object with the given path to the scene.
# Eaxmple
1. __VideoPostHelper__ : Get the renderer id and version, set the render settings.
2. __AOVHelper__ : Add/Remove/Set/Get aovs, and print aov info.
3. __MaterialHelper__ : Create an Octane material with nodes and print shader info.
4. __SceneHelper__ : Create lights/tags/objects.
# Version & Updates
- **0.1.0** : octane_helper and node_helper is beta now. ([email protected])
- __coming soon...__
Following....
ShivaMist
Thank you for your work DunHou it will help a lot to do some serious automation in a pipeline :)!
WDH
ShivaMist wrote:Thank you for your work DunHou it will help a lot to do some serious automation in a pipeline :)!
Thanks for that!
