Coating layer bug on universal material :
Coating remove bumps if there in sheen layer too with bumps connected to it
SSmolak wrote:Coating layer bug on universal material :
john_otoy wrote:SSmolak wrote:Coating layer bug on universal material :
I cannot reproduce this, but I also cannot see all your material settings in the video. Please provide simplified scenes in addition to your videos.
Zay wrote:I tried this HDRI https://polyhaven.com/a/je_gray_park .
Doesn't seem like the AI denoiser likes it as it will shift the texture and it's still noisy.
SSmolak wrote:john_otoy wrote:SSmolak wrote:Coating layer bug on universal material :
Here is scene. Please try to increase coating.
It looks like Sheen Bump interfere with Coating.
john_otoy wrote:I noticed this HDRI has a very bright sun which will clip by default. Click settings (spanner icon) on the RGB image node and set the texture import type to 32 bit float. Does this help?
john_otoy wrote:You have attached an OCS which is missing the geometry and textures. Please export an ORBX.
thanulee wrote:Hey guys,
Texture displacement cannot use the border modes on an image texture.
If i use eg. clamp values or white borders on an image, it still sees that as “wrap around”.
Is that a limitation or a bug? I was told to post here instead of c4d forums.
Let me know! thanks a lot
Return to Commercial Product News & Releases (Download here)
