Storing render AOV settings in Cinema 4d take system
gricceri
Hi, I would like to store the "Render layer" parameters in Octane Render settings inside a take.
Currently I'm using a python script to achive this, but seems to put C4d in an unstable state resulting in frequent crashes while executing a "Render all marked takes".
import c4d
doc: c4d.documents.BaseDocument
ID_OCTANE_LIVEPLUGIN = 1029499
def main():
    rd = doc.GetActiveRenderData()
    octane = rd.GetFirstVideoPost()
    if enable:
        octane[c4d.SET_RENDERLAYER_ACTIVE] = 1
    else:
        octane[c4d.SET_RENDERLAYER_ACTIVE] = 0
    octane[c4d.SET_RENDERLAYER_ID] = layerid
    c4d.EventAdd()
Here "octane" maybe NULL, check it!
gricceri
aoktar wrote:Here "octane" maybe NULL, check it!
First of all thanks for the quick reply!
I'll add this check, even if I actually print octane.GetName() to the console and seems fine.
I've changed the expresso node priority to Genarator 400 and so far stability as improved a lot.
But yet would be nice to store Render Setting inside a take.
Bests.
gricceri wrote: But yet would be nice to store Render Setting inside a take.
Bests.
Storing by who?
gricceri
Bests.
Storing by who?
Sorry, I mean adding an override. Like in my case overriding the "layer id" in AOV renders settings in a particular take.
