I have been hammering away at solving this and I can't fix it.
Running the latest stable build, As soon as I enable path tracing Octane will start pushing my GFX cards and kill the system. Screens go black and the fans go into overdrive.
This happens in 2023 or r26.
Every other render engine (Arnold and Redshift) works fine. It's just octane
Last log file attached.
System:
Threadripper 3070
128GB RAM
Dual rtx 3090
Octane crashing my computer
- c4doctanelog.txt
- (112.7 KiB) Downloaded 54 times
please perform a clean installation of 516.94 Nvidia Studio driver:
https://www.nvidia.com/download/driverR ... 969/en-us/
To perform a clean installation, please follow these steps:
Then please, after reboot, download and run OctaneBench 2020.1, and share a complete screenshot of the result, thanks:
https://render.otoy.com/downloads/a/61/ ... _5_win.zip
ciao,
Beppe
ciao,
Beppe
I would agree, it as I stated octane is the only rendering engine that is causing this. I have tried it with Arnold as well as Redshift and Cycles and none of them have this issue. I can even push large scenes through Clarisse and I have no problems.
If also OctaneBench is crashing, the system seems not quite stable to me
Ok, please try to go to Nvidia Control panel, menu Help, and enable the Debug mode, to work with GPUs at default clock, and run again OctaneBench:
ciao,
Beppe
ciao,
Beppe
Octane is a GPU renderer, among all the ones you've mentioned, only RS is one (natively and originally). Unless you are on Clarisse Angie which is not yet a stable hybrid renderer, or Cycles GPU/forked GPU version.Anim8me2 wrote:I would agree, it as I stated octane is the only rendering engine that is causing this. I have tried it with Arnold as well as Redshift and Cycles and none of them have this issue. I can even push large scenes through Clarisse and I have no problems.
If Octane is causing the crash, it would usually imply that it is triggering an issue that the others don't.
Further troubleshooting is definitely required. Do keep us updated.
I have checked every component and reseated all cables. I have also unplugged one of my graphics cards to remove power draw on the system, but the issue persists. I have also tried using the Octane version of Blender and it works without crashing. C4d and Octanebench still crash.elsksa wrote:A crash often relates to a hardware failure. It would be suggested to look at hardware level (motherboard & PSU connections, properly powered components, etc).
