MantasKava wrote:(...) I must admit it's a bit much for me to digest it all in one sitting.
Indeed, it's quite overwhelming at first and "won't happen over night". Take your time. The reward is worth it.
MantasKava wrote:
1. Main reason (for me) for using/trying ACES is to get rid of constant clipping/overexposed/burned highlights, or not nice looking highlights in general (it's a problem when working with interiors, especially).
Filmic AgX does the same, in a much simpler way, with minimized visual flaws, as opposed to ACES.
MantasKava wrote:
There's an over-saturated highlights problem also. And ACES helps tremendously in this regard, no burned-out/clipped highlights anymore.
Aside from the highlight roll-off, ACES has hideous color-skewing (e.g. red will skew to orange, blue to cyan, etc), always visible on intense light sources and any surface reflections, including highlights.
MantasKava wrote:
I'd even say highlights get compressed too much. Which is another problem and that is the reason why I started this topic to begin with).
That's by design (Reference Rendering Transform aka RRT, which outputs is called "OCES") from where the "filmic aesthetic" comes from (in reference to the celluloid film medium) and has been a topic of discussion reported to them (a long debate). The end-user can't do anything about that. The subjective ACES look is also not appreciated by everyone.
MantasKava wrote:
Question- am I choosing the wrong solution for my problem?
This answer has been
spoiled.
MantasKava wrote:
2. If ACES is so "bad" for 99.9% of the users, why is such a major developer as Maxon/Redshift implementing it into their software as default? Hard to believe they are too stupid to know this stuff.
❝Just because everyone is doing it, doesn't mean it's right. And just because no one is doing it, doesn't mean it's wrong.❞
Digital Imaging is an entirely different domain with its own research & development fields, scientists, etc.
It's not what developers specialize on, nor majority of end-users. Awareness is highly important.
Octane just output light data. It can then be managed in various ways, with OCIO or without, which would imply a higher level of knowledge and skills from a digital imaging technician/colorist. Filmic AgX is the only reliable solution out here, for those that do not specialize in advanced post-production.
MantasKava wrote:
3. What file format/bit depth/color space should I use when exporting for PP in an external app (Fusion in this case) when using Filmic AgX or Filmic Blender?
The gold standard and primary choice is always:
OpenEXR, 16-bit (for beauty, and 32-bit for data AOVs).
The "compression type" depends on various factors, the choice is yours. Otherwise, TIFF.
Some more information.
MantasKava wrote:
4. Which one do I select here? If I want to export for PP in Fusion.
If you plan to replace ACES with Filmic OCIO AgX, any ACES option is completely irrelevant (as there are some native ACES options in Octane).
Looks like it's AgX loaded, it would be: Linear BT.709 (the exact same as Linear-sRGB).
I'm not familiar with Cinema 4D GUI, it's not 1:1 matching Standalone since it's part of a 3D DCC.
On Standalone, default settings are correct. I don't know how is this handled in Octane Cinema 4D.
I will update my Octane pages with that AgX setup information.
MantasKava wrote:
5. Is this the right OCIO View option when using Blender Filmic? Every other option looks really wrong I found.
Looks like this one is the original ("legacy") Filmic OCIO.
I would recommend to stick with AgX as it is a drastically improved version.
To answer:
• The first one is the Log-Encoding, similarly to the log encoding from digital cinema cameras.
• The second one is the conforming from Log-encoded (OETF) to display (EOTF).
The original Filmic OCIO package offers various "contrast intensities", which go from "base contrast" up to "high contrast", and everything in between (in addition to two bonus options: black-and-white & false color).
MantasKava wrote:
6. What is this button for?
It's to apply the "ACES Look" using the official ACES implementation, without the need of OCIO.
It's explained
here, and also why it's a limited option (no post possible when using it).
