olavo
I finally upgrades my Intel iMac Pro to Monterey and fortunately everything stil works great with my RX6900 XT egpu.
So I am now using PR14 and at first it looked rock solid, but now I get crashes when working in the node editor. PR11 did also gave me these crashes so I hoped this was over now. Will PR14 be the last version for Intel?
thanks, Olav
Sirajhassan
Do we have a native Octane for M1 mac or we still need to run in rosetta mode ?
We still need to run in Rosetta mode.
2022.1-XB2 is out with several fixes, but not native for M1 yet:
viewtopic.php?f=33&t=79999
The native M1 version should arrive with next XB3 update.
ciao,
Beppe
barnygeroelheimer
Hi, any help would be greatly appreciated, Octane not working with this configuration:
Thank you!
MacPro 7,1
macOS 12.4
Cinema 4D R25.120
Octane PR13/PR14
with both Octane versions console is outputting this:
Loaded Octane DLL:Octane X Studio PR13 version:10000307 SDK:PR13
Octane X for Cinema 4D PR13 built for:250 C4D vers:25120
C4D:25120 comp:[MUT-20-L0288.mutabor.de] OS:[OS X 64 BIT] macOS: Version 12.4 (Build 21F79) versType:10
CPU:[GenuineIntel, stepping 7, model 5, instruction family 6] speed:3.3 GHz numOfCpu:24Ht
Plugins:[addons advanced_render alembic archigrass assetbrowser bitmapfilter bpexchange browser bugslife_client c4d_emulation c4d_viewport_render c4doctane-R25 ca ca2 cadexchange clothilde collada14 collada15 colorchoosergui compositing deltamush deployment dwg dwgobjects dynamics exchanges expressiontag fbx gltf goz hair i_skp interop interop_forger io_forger io_obj metrics mkmodeler mocca model mograph motioncam motiontracker nbo nbp newman nodeeditor objects onlineupdater physx_hybrid projectassetinspector python redshift relaxuv scenemanager2 sculpt sculptbrushes shader sketch sky sla spacemouse substance teamrender thinking_particles tool_system_hybrid tpoperators usd uvviewport volumes xpressocore xtensions ]
Loaded 89 osl scripts from dir:/Applications/Maxon Cinema 4D R25/plugins/C4D-OctaneX-Studio-PR13/res/osl_scripts
VRAM used/free/max:0Kb/8Gb/8Gb Out-of-core used:0Kb RAM used:56.017Gb total:96Gb OpenGL free/total:0/0
FumeFx library initialisation error!
Multi-threaded material conversion, thread count=22
Export materials time= 0.091 ms
Collect objects time= 0.018 ms
Mesh creation time = 1.783 ms.
Api update time: 0.03 ms.
<<< Render failure detected!!! >>>
Please check render statistics to solve the problem.
MB:0/0 ST/MOV:0/0 Nodes:10 Tris:0 DispTris:0 Hairs:0 Meshes:0
Textures Grey8/16:0/0 Rgb32/64:0/0
>> ProcessUpdate(flags=CMO cAsyn=1 dDelay=1
>> ProcessUpdate end res:0
File not found:/Users/daniel.hummer/Library/Preferences/Maxon/Maxon Cinema 4D R25_EBA43BEE/updates-ox.txt
Log:
Started logging on 23.06.22 11:41:30
Octane X Studio PR13 (10000307)
Compute error 2097152:814:
compute device 0: Linking 00696900aaaadec4 shader failed
device 0: failed to initialize render thread 0x7f8281ff6d40
danchosich
Beppe,
Is that 2022.1-XB2 version going to have a C4D Mac Plugin? Or are you waiting for XB3?
If you are waiting for the release of XB3, do you know the ballpark timeline for that release?
I have a job that could use a bunch of the fixes in it.
Thank you,
Dan
Hi Dan,
yes, for C4D-OctaneX native plugin we need to wait for the next 2022.1-XB3 version.
Difficult to give an ETA, it could take from four to eight weeks or even more, but since it will be the first alpha version for M1 native plugin, my suggestion is to avoid to use it in production, the generated files could be unusable with future stable version.
ciao,
Beppe
martinzip
Dear Beppe,
does it means, the next OctaneX 2022 release will be only working on M1/M2 and not with AMD GPUs??
Martin
elsksa
bepeg4d wrote: M1 chip is completely different from previous CPUs, and does not have the necessary AVX2 instructions for performing AI Denoiser, and Denoised passes.
So AI Denoiser, and denoised passes must to be disabled, or the render never finishes.
Alternatively, you can try with Hot pixel removal slider in Camera Imager node, but avoid to go under 0.65, and consider that it is distructive, so you can have artifacts.
Another option is to try with internal C4D Denoiser in Picture Viewer, but it is not like AI Denoiser:
ciao,
Beppe
Alternatively, denoising can be done in post (Nuke, Fusion or else) using native or (usually) third party denoisers.
grrigoryan
Hello colleagues!
I'm new to 3d animation
After installing OctaneX, I have this error in C4D
What version of OctaneX do I need and what should I do?
I searched here on the forum for my problem and did not find it
/Users/grrigoryan/Downloads/IMG_5621.HEIC
characteristics of my macbook pro 2020
/Users/grrigoryan/Desktop/Снимок экрана 2022-07-03 в 18.47.20.png
/Users/grrigoryan/Desktop/Снимок экрана 2022-07-03 в 18.48.40.png
Hi grrigoryan,
unfortunately the screenshots are not visible.
Please use ther Upload attachment button while you are compositing your message:
ciao,
Beppe
