Caustics, Photon tracing and something missing?
JPeg
Hey all,
I've been testing out the XB0 release of 2022.1 for some caustics renders and have a specific question.
I know this feature is very early development but I hope by feedback is received well :)
So far I've managed to produce an image with sidefx's Mantra engine that I feel represents the most "accurate" example I've come across and I've been trying to match it in other engines to hopefully resolve the image faster. Redshift was giving me fairly OK results but when I pushed the photon count to the max my RTX 3090 could allow it still came out more noisy than Mantra and was slower to render. This is where Octane Photon tracing kernel seems to shin! The memory overhead is the lowest of any engine I've tested and there is so waiting for photon map generation, it just starts instantly and resolves quickly, nice!
So with the good news out of the way here is the bad; there is either a missing indirect component or I can't find where to "enable" this in the software.
First here is my "master" reference created with Mantra, you can see there is some light scattering within the prism so its not completely black and there is indirect light bounce back onto the ground plane as well. To achieve this in Mantra I'm using 2 indirect lights "Caustic Photon Map" + "Indirect Global Photon Map" with the PBR render settings on "All Paths" vs the default "Specular, Diffuse Paths". Render time about 55s
The redshift result isn't bad, but prism is very dark, the bounce light onto the ground plane is working well though, here there is more noise than the mantra render and the render time was slightly higher at about 70s
Now onto Octane, this first result is with bounce settings matching Mantra, diffuse depth of 2 and specular of 6, at 2000 samples it rendered in 19s. But the scattering within the prism is missing and there is no diffuse bounce on the ground plane.
I tried increasing all the bounce settings along with a 10x increase to the light strength and you can see there are photons bouncing around there but after 10 minuets rendering this is the result I got, its very noisy and still far from my reference
Can anyone point me to either where I'm missing something or a dev chime in with why there is this difference? I'm happy to provide orbx file if needed!
grimm
It looks like you are missing some roughness on the ground plane and/or the prism? I think that is where you will see a lot of the diffuse scattering. I would like to try out your file if possible?
JPeg
thanks, playing with the roughness does in some ways bring the "scattered" look into it, but does nothing for the ground plane. All my other renders were done with 0 roughness. I've attached the orbx :)
prisCaustics_001.orbx
(88.51 KiB) Downloaded 220 times
JPeg
Playing with roughness a bit more and added a Sheen layer, the sheen produced the bounce light back onto the ground, but with an extra unwanted reflection on the prism.
The this is with 10000 samples 3min render time
EDIT:
After more tweaking of coat/sheen and their roughness values, I did finally find the look! (added an extra light too with a wider cone angle). I did find playing with these settings enough (and this applies to RS as well) ends up giving a result like the one I got from Mantra (that didn't have any coat/sheen). Still not sure why there is this shader difference, but happy with the results :)
This is with 4000 samples at a render time of 73s, which puts it roughly inline with mantra/rs in render time, but I'm really liking the look/qualities of this! Just need the denoise filter enabled for Photon tracing now :D
One extra note, compared to my other renders, the Photon Mapping kernel seems to drastically improve on everything else when it comes to photon count; I see a far higher density of photons much quicker, with less memory overhead! This is very promising!
grimm
That is great you got it working. I was thinking too that this is still beta, there might be some other issues that keep Octane from getting similar results?
