Can you use an image SEQUENCE in MODO Octane?
Forums: Can you use an image SEQUENCE in MODO Octane?
Postby Greg » Wed Apr 04, 2018 7:18 pm
Greg Wed Apr 04, 2018 7:18 pm
Hmmm, I need to use an image sequence (rather than just a still image) for a material. I'm not sure how to set this up in Octane. Adding an Octane override does not seem to convert an imaqe seq. into the correct nodes. Any help on this?
CEO Sabertooth Productions
Co-Founder Pixel Fondue
Greg
Re: Can you use an image SEQUENCE in MODO Octane?
Postby iQboost » Wed Apr 04, 2018 8:58 pm
iQboost Wed Apr 04, 2018 8:58 pm
maybe this is helpful? fingers crossed.
https://render.otoy.com/forum/viewtopic.php?f=34&t=62329&p=318634&hilit=image+sequence+modo#p318634
Hi - ideally the plugin would allow images sequences for the environment texture (as it does for materials). I will add this to the TODO list for the plugin.
________________________
https://render.otoy.com/forum/viewtopic.php?f=34&t=55078&p=317462&hilit=image+sequence+modo#p317462
In your scene you have the visible background set to a Front Projection camera. Whilst this is supported by the plugin for materials, it is not supported for the Environment texture. Instead, enable Kernel->Alpha Channel and use Photoshop, Gimp, etc to paste the rendered image over your background.
iQboost
Postby face_off » Thu Apr 05, 2018 4:15 am
face_off Thu Apr 05, 2018 4:15 am
Images sequences are automatically supported for on-the-fly Modo to Octane conversions. But not in Octane Overrides.
Following are some relevant points from the release notes...
- Fixed crash with Image Sequences (introduced with the OCIO support change in 3.6.3.117). At this stage, image sequences will be assumed to have a gamma of 2.2
- Added better support for Image Sequences. First Frame, Last Frame and Start Frame are now supported. Only End Behavior is assumed to be "Hold". FPS Multiplier is assumed to be 1.
Postby Greg » Thu Apr 05, 2018 7:11 am
Greg Thu Apr 05, 2018 7:11 am
Ah - great. Thanks, Paul. I should have tried the easiest solution (I always add Octane overrides by default)
-G
Greg
Postby OlaHaldor » Fri Nov 29, 2019 2:38 pm
OlaHaldor Fri Nov 29, 2019 2:38 pm
Is this still a problem?
I have a displacement map I'd like to use on a plane that I've shaded to look like water. Only thing missing now is to get the displacement working!
Modo & LightWave 3D | Win 10 x64 | RTX 2080 Ti | Threadripper 2920x | 128GB
OlaHaldor
Postby face_off » Sat Nov 30, 2019 2:55 am
face_off Sat Nov 30, 2019 2:55 am
Please check the Release Notes at https://render.otoy.com/forum/viewforum.php?f=34 for better support for Image Sequences.
Postby OlaHaldor » Mon Dec 02, 2019 8:29 am
OlaHaldor Mon Dec 02, 2019 8:29 am
- Added support for Modo Image Sequences in Octane Overrides. To use this, drag the image sequence clip into the Octane Override schematic panel, and then connect the "pattern" chanenl to the Image node filename pin
I don't see a pattern channel anywhere.
I tried connecting any and all channels from the pins from the two nodes that came by dragging the clip into the schematic, but none will connect.
OlaHaldor
Postby face_off » Mon Dec 02, 2019 10:44 am
face_off Mon Dec 02, 2019 10:44 am
Add the "pattern" channel to the Image Sequence node, and then drag that channel to the Filename pin on an Octane RGB Image. I will get the Octane plugin to auto-add the "pattern" channel as it does the "filename" channel in the next release.
Postby OlaHaldor » Mon Dec 02, 2019 1:35 pm
OlaHaldor Mon Dec 02, 2019 1:35 pm
Add, as in "add user channel" ? Terribly sorry if I look stupid; could you share a screenshot to explain ?
OlaHaldor
Postby face_off » Mon Dec 02, 2019 10:42 pm
face_off Mon Dec 02, 2019 10:42 pm
In the schematic, rightclick the Image Sequence node ("ocean_[####]" in your screenshot) and "Add Channel"->"pattern".
Return to Foundry Modo
Wed May 29, 2024 7:24 am [ UTC ]
