I would like to be able to custom color the density of a volume according to velocity values, but how? Think of it as a kind of high end engineering visualization.
In Arnold one can simply use the Volume Sample RGB shader to "sample" vector values that then can be fed into the color of the density/scatter. I can't seem to figure this out with Octane?
https://support.solidangle.com/display/ ... Sample+RGB
Also, any news on supporting attribute values such as color with regards to shading? Are there any workarounds at the moment? Can the data be fed into the stand alone version, if it is a plugin limit?
