My displacement problem
Moderator: JimStar
sampakinpa
export setting from zBrush. tif 16 bit worked best foer me.
2x Xeon E5-2620, 32 GB RAM, 4X GTX1080ti, Windows 10, Octane 3 for Maya 2018, Radeon HD6450 for disply BRIO Animation ltd
prodviz
Looks great, cheers.
However, there's a very small negative offset, so I wouldn't expect many issues.
linvanchene
sampakinpa,
Thank you so much for sharing! :D
It helps me a lot to understand why I run into problems with other displacement maps.
The fiber mesh eyebrows and eye lashes look amazing as well!
Win 10 Pro 64bit | Rendering: 2 x ASUS GeForce RTX 2080 Ti TURBO | Asus RTX NVLink Bridge 4-Slot | Intel Core i7 5820K | ASUS X99-E WS| 64 GB RAM
FAQ: OctaneRender for DAZ Studio - FAQ link collection
sampakinpa
Thanks for the compliments.
Why is it?
Hair, eyebrows and lashes are Maya hair rendered with Octane Hair.
prodviz
I don't know why, but it appears that the offset with negative setting are causing issues with the geoemtry.
Your offset is of a very small value, so I guess this is why you're not having any issues.
sampakinpa
My displacement issues was solved when I started to work with 16 bit displacement maps from zBrush instead of 32 bit.
prodviz
Cool, good to know.
For me, the 16 bit version was a little better than 32 bit file.
I was working with a displacement which needed a larger negative value, which still caused geometry issues.
gordonrobb
The issue seems like the shift uses a different calculation to the displacement. So if you have a large negative value it invariably tears bits of geometry.
franchus
This is fixed using a ClampTexture node between the texture and the displacement node. The explanation of this is: Octane assumes gets the 32 bit value of an image, therefore there might be higher than 1 and lower than 0 values. The Clamp node corrects the interpretation issues.
Return to “Autodesk Maya”
