Random Color changes randomseed during animation
coilbook
Hi does anyone know why would random color seed just change during animation making my trees in background different color. Thank you
random_color.mp4
(2.85 MiB) Downloaded 1783 times
coilbook
answered my own question
i think itoo forest changes random color seed if trees/ grass are assigned to active camera view that lets grass to be visible only in camera
random_color_grass.mp4
(998.9 KiB) Downloaded 1774 times
coilbook
itoo forest reply
"Thanks for reporting the problem. It seems random color texture uses the object's geometry to compute random seeds, so in this case it generates different values because geometry is non-static.
Unfortunately we cannot fix the problem. This is something should be checked by the Otoy team."
Karba
coilbook wrote:itoo forest reply
We are planing to use special seed values per instance which should be constant from frame to frame. At the moment there is no way to keep color with changing object number.
coilbook
Return to “Autodesk 3Ds Max”
