Amazing work! Do you mind posting the raw images from octane?
Which plant library did you use?
Nectar : Media Center Bar (exterior & interior)
Wow, very impressive work as always, but this is a really big project !
Nice place as well. I just wonder where the water of the fountain comes from !
Probably a hidden tube in the concrete with discrete joint with the sculpture base...
- enricocerica
- Contact:
Thanks again to everyone,
Yep, you guess it, a hidden tube in the concrete, I had to make several tries but it works fineROUBAL wrote:Wow, very impressive work as always, but this is a really big project !![]()
Nice place as well. I just wonder where the water of the fountain comes from !Probably a hidden tube in the concrete with discrete joint with the sculpture base...
All the plants are home made with my own Blender 2.49 generator script.geo_n wrote:Amazing work! Do you mind posting the raw images from octane?
As said evrything was rendered using DL AO and it's quite difficult to avoid strong tonal, I should have used DL Diffuse or PMC to get more indirect light and a softer result but the time price is really high with such scenes.gabrielefx wrote:very nice interiors
I think you applied a very dramatic post, too strong tonal contrast.
Modeling system : I7 32GB Windows 10 & Fujitsu Celsius H720
GPU : 1x Gigabyte GTX580 3GB + 1x MSI GTX780 3GB + 1x PALIT GTX780 6GB +1x Asus Stix GTX1070 8GB
http://www.myline.be
As others Said...amazing renders Enrico...
any tips u could share regarding your workflow of Direct Light and AO?
Especially for interiors please!
Nildo
Nildo
Corei7, 6x GTX1070 (2 Inside and 4 in a CUBIX Xpander), 32GB Ram, Win10 64Bit Home, 3dsMax2017 64Bit, Octane for max 3 and LOVING IT!!!!
MSI GT72S 6QE Dominator Pro G win10Home, gtx 980m.
- cyNickalCyn
- Contact:
Amazing
Great work, looks very realistic from every angle!
I have such a long way to go, one day I will break free from the shackles of poser and it's purchasable content
1x 8GB Nuhvidia GTX 880M
32GB DDR3 RAM 1600
2x SSD 480GB
i7-4810MQ
32GB DDR3 RAM 1600
2x SSD 480GB
i7-4810MQ
- enricocerica
- Contact:
Well no secret and no miracle, even with DL AO, light is the key. So try to let the light entering in any way. In this scene I made the ceilings emitting, not too much as it shouldn't be perceptible but enough to add some more light inside the building. I usually reduce the AO distance to 2 or 1.5 to avoid too much darkness. I also change the sky and floor colors for the sunlight to something quite white to get a more natural result. Anyway in all the cases the images will need more or less work in postpro to try to get a less fake result.nildoe wrote:As others Said...amazing renders Enrico...
Nildo
Thank you for the tips Enrico, when you say color of the sky and floor..you mean actual colors of the sun object?
Nildo
Nildo
- enricocerica
- Contact:
Surenildoe wrote:Thank you for the tips Enrico, when you say color of the sky and floor..you mean actual colors of the sun object?
Nildo
