Billiard Balls
GeoPappas
This is my first render.
Nothing nearly as exciting as many of the other renders here, but I felt like sharing.
Anyone have any ideas for how to make a green felt procedurally?
Comments and suggestions welcome.
Kernel: directlighting
Render Time: ~ 1 hr (@ 1050x600)
Samples: ~ 2500
Win 7 Home Premium (64-bit) | Intel Core 2 Q9550 2.83GHz Quad-Core | GeForce GT 240 1GB PCI Express 2.0 x16 (NVIDIA driver v. 266.58 WHQL) | 4 GB DDR2 RAM |
radiance
You really need to think about getting a propper GPU, a 9400 really is ultra-slow...
I'd try a turbulence with the scale set very high on the bump channel.
Radiance
GeoPappas
radiance wrote: You really need to think about getting a propper GPU, a 9400 really is ultra-slow...
Thanks for the reply.
Yes, I know that the 9400 isn't the bleeding edge, but it ain't THAT slow. I plan on getting a GT 240 in the next few weeks. It seems to be at a good price point. I would love to get a GTX 480, but can't afford it at the moment.
radiance wrote: I'd try a turbulence with the scale set very high on the bump channel.
I'm not sure I'm understanding your suggestion. I made the bump channel turbulence and then played with the scale, but it didn't seem to change anything. I must be doing something wrong.
GeoPappas
Here is an update.
I changed the kernel to pathtracing, upped the saturation slightly (to 1.5), and changed the color of the "felt" to a darker green.
Kernel: pathtracing
Render Time: ~ 3 hr (@ 1600x1200)
Samples: 2000
GeoPappas
I'm not sure I'm understanding your suggestion. I made the bump channel turbulence and then played with the scale, but it didn't seem to change anything. I must be doing something wrong.[/quote]
OK, I just tried it again, and this time it seems to be working. Must have been user error the last time. I'll try to play with it and see if I can get it to look correct, although at this time a large amount of fireflies seem to be present.
radiance
OK, I just tried it again, and this time it seems to be working. Must have been user error the last time. I'll try to play with it and see if I can get it to look correct, although at this time a large amount of fireflies seem to be present.[/quote]
when working with procedurals, the power of the procedural needs to be very tiny on a bump map, something like 0.1 or even less.
Radiance
GeoPappas
Here is the latest update:
- I added a felt image texture.
Comments welcome.
Kernel: pathtracing
Render Time: ~ 4.5 hr (@ 1600x1200)
Samples: 2500 (it probably looked good a long time before this - I just set it up to run for a while overnight)
radiance
very good, but i'd try to make the scale a bit higher (eg so the texture is smaller/finer).
and also add a very small bump with also a turbulence...
Radiance
prophet
I'd suggest adding a bit more reflection as well.
Return to “Works In Progress”
