Beta 2.2 RC1: Blender 2.49 Export Script testing thread
Locked
enricocerica
James wrote:saikafu: The sun angle is taken from the orientation of the lamp rather than the position, try changing the lamp to a sun type or area (any lamp that shows the direction it is pointing) and rotate it.
Good point James, Saikafu, good you first check if you are using a sun light and not a lamp which hasn't direction.
Modeling system : I7 32GB Windows 10 & Fujitsu Celsius H720
GPU : 1x Gigabyte GTX580 3GB + 1x MSI GTX780 3GB + 1x PALIT GTX780 6GB +1x Asus Stix GTX1070 8GB
http://www.myline.be
saikafu
thanks everyone
i'll keep test~~
James
I am making a video on how to use it now. Finally got some screen recording software that works.
Kubuntu 9.04 | Nvidia Gainward 9500 GT | Intel Core2 Quad 2.40 Ghz | 4 GB RAM
radiance
enrico -> you might want to use the \"some file\" when exporting on linux for filenames, so spaces will work.
Radiance
enricocerica
radiance wrote:enrico -> you might want to use the \"some file\" when exporting on linux for filenames, so spaces will work.
Radiance
Yeah, I know and I'll add it in the next version ;)
James
ROUBAL
Thank you very much for this great script and for the tutorials.
I have done my first animation test with Blender and Octane. It has been easy, and the warnings in the exporter helped me a lot (I had spaces in my paths).
This said, I encountered a weird trouble in the render and I don't know if it is due to the exporter or to Octane : There is something flashing in the video. It is probably the sun lamp.
Here is a link to my first video :
http://vimeo.com/11944801
enricocerica
@James:Hey that's great and it may help several people to well handle the script ;)
@Roubal:Just wait for the RC3 which should arrive soon to check if the flash problem still occure, by the way it shouldn't come from the script imo.
ROUBAL
@enricocerica : OK, thank you for your response. I will wait for RC3.
Thanks to the script, I am currently rendering an animation test of 35 frames with an animated character.
Beside the fact that I have a problem of focus with the camera (I still have to check some things before reporting about it precisely), I am really disappointed (But I had the fear that it would happen) by the loading time of each frame.
For a simple scene of 290MB (only the character (detailed model) and a ground plane, with raw materials only and no texture loaded), it requires 124 seconds per frame of loading on my GTX 260 in a X-Pander box, versus 4 seconds of rendering at 32s/px.
This mean that at 992 samples per pixel, the loading time is equal to the rendering time ! If you consider that I plan to purchase some bigger graphic cards to manage scenes up to 1.5 GB at least, even with more computing cores, the total treatment of each frame will be really huge, almost only due to the loading of the obj and materials ! :cry:
For animations, the gain of time during the interactive setup process of materials seems to be sadly compensated by the very slow loading process of each frame.
I hope that there is or will be a solution to that problem, because this could pull me back to CPU rendering...
Faizol
ROUBAL wrote:@enricocerica : OK, thank you for your response. I will wait for RC3.
Loading and offloading obj files are an expensive operations. The same thing with writing files to the disk. I guess optimization in this area and other parallelization are expected once the rendering engine is set in place so I wouldn't worry too much about it. Plus, Octane will support file format that supports animation, then hopefully we won't have to load and offload objs frame by frame anymore in the near future.
Fedora 17 | 16 GB RAM | Quadro 4000 | driver = nvidia 304.xx & CUDA 4.0
Locked
Return to “Blender”
