volume fog in 1.11
face
archigrafix wrote:What version do you use? I am on 1.11 and dont see no fog node...
Nor any file supplied by Karba
Use a specular cube with a scatter which is the fog. In the specular node, turn on fake_shadows.
Place the meshes inside this cube and the camera outside.
face
http://vimeo.com/user2509578
p3taoctane
The file is in the 1.1 release message
It is the way you set up a specular file and the accompanying light sources.
I'm swamped today but will post a screen shot as soon as I can
Karba's file will illustrate the settings well too.
mib2berlin
Ah, thanks, found the file on page 5.
Cheers, mib.
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
Synthercat
+1
Linux Mint 19.3 | GTX-1080Ti | AMD FX-8320 (OCed 4.4GHz) | 16GB RAM
Synthercat
face
Oh! I just saw that post. Thanks man!
ROUBAL
Are you sure ? I think that in the example file, the camera is inside the fog volume. I can't verify right now, as I am not on my workstation with Octane.
enricocerica
ROUBAL wrote:Are you sure ? I think that in the example file, the camera is inside the fog volume. I can't verify right now, as I am not on my workstation with Octane.
I think that the camera is outside, just because I tried with the camera inside the cube, which would be much useful and it doesn't work, I've tried all the ways and nope :(
If someone has an idea on how to get the fog result with a camera inside the fog, I would be really happy ;)
Modeling system : I7 32GB Windows 10 & Fujitsu Celsius H720
GPU : 1x Gigabyte GTX580 3GB + 1x MSI GTX780 3GB + 1x PALIT GTX780 6GB +1x Asus Stix GTX1070 8GB
http://www.myline.be
face
enricocerica wrote: I think that the camera is outside, just because I tried with the camera inside the cube, which would be much useful and it doesn't work, I've tried all the ways and nope :(
There is a tricky way, i used inside Softimage. For this i need only 2 cubes.
One cube is constrained to the camera position and follow the movement of the camera. The other one is the volume itselft.
Now i bool they together with mode difference and hide the both cubes. The result i get is now a small cube where is nothing, inside a big cube, where the medium is.
Because the boolean is interactive, at least in Softimage, the result is always up to date if i move the camera.
It is also possible to constrain the direction of the cube to the camera, so the camera is alway looking parallel to a face, but i think because a fog is fade in slowly, there is no need to do that.
I have moved the camera in the example to an edge to show the result.
face
abstrax
Try it with a small sphere around the camera, that has the normals pointing inside (i.e. towards the camera) which has the fog material. I think you need "tell" Octane that a path enters the volume, you do that by having some surface with a material with a medium.
manalokos
yes, just make a sphere with inverted normals with a placement node with camera coordinates, with the same scattering material of the volume bounding box.
By the way, octane team! You could make an output port for the position of the camera to automatically contrain position and orientation of objects to camera.
Best regards
Filipe
