Hi everyone,
I got the matrix transformation to one object using max script.
I selected the object and I used this comand line: ''Transform_matrix = $.transform''
Then the answer was (matrix3 [4.97326,0.871754,0] [-0.871754,4.97326,0] [0,0,5.04909] [87.0011,-93.2884,0])
ok I was happy then I opened Octane Stand Alone and past the code (4.97326 0.871754 0 -0.871754 4.97326 0 0 0 5.04909 87.0011 -93.2884 0) in scatter node.
My object appears warped, probably because the way that 3dsmax generates the matrix isn't that correct for octane read.
Could anyone help me with this? I would like use simple Object Paint in max then extract the correct matrix for octane.
matrix in 3dsmax
While I'm not a max user, I can tell that the structure of the data you pasted is not properly formatted for what the scatter node is looking for as an input. I could be wrong, but your data is 4 sets of 3 values (12 total), where the correct structure would be 3 sets of 4 values (still 12 total). The correct input is a 4x4 matrix where you leave the bottom row of (hence 3 sets of 4). Take a look at the pdf in the link below and maybe it may make more sense, there is a section which goes into explaining what the different values mean in the matrix:
http://www.grasshopper3d.com/profiles/b ... ics-second
To reframe AleksBraz's question, does anyone know how to modify what was pasted from max to get the scatter to work properly? Or do you know another way of getting the 4x4 transformation matrix data from an object in max?
Win 8 64 | 2X Geforce GTX680 | i7-3770K Ivy Bridge 3.5GHz | 32GB
Getting the transform from an object in max is as you wrote, $.transform. (4 point3's -> point3 = [0,0,0]) The last point3 is the position/translation.
The problem is probably that max up vector is Z and octane up vector is Y (i would guess).
You could try to switch the y and z values in each point3.
Hello
