3ds Max colour problem
Jani
Hello,
I don't know whether this is a bug, or I am doing something wrong(in any case, it's not mentioned in the manual), but when I put on a diffuse colour or a texture, it is always 'whittened'( I don't even know if thats the right word). I will try to put it simply:
Diffuse colour set in the material editor
3ds Max Viewport
Colour seen in the render viewport
Octane Render render window
//NOTE// even the material editor's quick preview does bad colouring, it does however show black normally
I have tried all the common sense things such as changing the kernel, playing around with gamma, texture environment/sun&sky, you name it..
Oddly enough, when I was using the demo, this didn't happen(the demo was a bit outdated though). Also, in the standalone version the colours look normal as they should.
Help please, my deadline is coming close.
i9 9920X, 64GB, RTX 2080Ti
Ryzen 1800x, 64GB, 2x RTX 3090
suvakas
Do you have Max gamma correction enabled?
Suv
Jani
Here's a set of screens disclosed... As said previously, I don't see where the problem could be.
If I crank up the gamma, the image just gets brighter and less colour-y, if I put it down, I see more colour, but not the right colours(it looks strange anyways)
As for the settings, both of the screenshots the render settings are the same.
Standalone Octane
Standalone Octane
octane 3ds max render
Karba
Jani wrote:Here's a set of screens disclosed... As said previously, I don't see where the problem could be.
looks like some plugin licence issue.
Please try delete all folder with names insdie {...} in
C:\Users\[your username]\AppData\Roaming\Refractive Software\ (just write %appdata% at your win explorer)
Jani
Karba thank you, that seems to have worked... :)
//EDIT//
There is another issue though, ever since I went from 3ds Max Octane Demo to FULL, I can't set the movable proxy boolean, when I right-click on an object, instead of the 'movable proxy' at the very bottom of the list I see 'Missing: 2398'. Is there a quick fix for this?
As I said, it happened straight after I got the full(paid) edition of 3ds max octane.
Karba
Jani wrote:Karba thank you, that seems to have worked... :)
//EDIT//
How do you set movable proxy?
Jani
Well, yes, that was what I meant, just the fact that it wasn't working for me :/
Missing: 2398
Missing: 2398
Karba
Jani wrote:Well, yes, that was what I meant, just the fact that it wasn't working for me :/
What plugin version do you use?
Jani
OctaneRender_for_3ds_max_2013_COM_v1.0_beta_2.58f
or so does the file I downloaded say...
//EDIT// It happened when I replaced the files in the 3ds max root from this to the newest version(I also replaced the .../plugins/ file):
OctaneRender_for_3ds_max_2013_COM_v1.0_beta_3.03_demo
Karba
Jani wrote:OctaneRender_for_3ds_max_2013_COM_v1.0_beta_2.58f
2.58f doesn't support instancing.
Use RC3
Return to “Autodesk 3Ds Max”
